2023-12-01 Libre Computer AML-A311D-CM AI SOM (Pre)
Libre Computer AML-A311D-CM, part of our Cottonwood family, is a permant AI-enable system on module designed for compute-intensive applications. It provides all of the capabilities of AML-A311D-CC with the flexibility of implementing custom carrier boards for capability multiplexing.
Will this be released at the same time as the AML-A311D-CC board, and is there a planned format for the carrier board connection? Great work!
This is mostly compatible with the Raspberry Pi 4 CM module with some improvements. It will be generally available March 2024.
any word on the AML-A311D-CM?
When this CM will be available?
The capabilities of the CM are much more extensive than the capabilities of the CC boards so a lot of additional testing and software bringup is needed. It is expected to land around Christmas and the halo project using it landing in Q1.
Will it be compatible with RPi carrier boards?
Most carrier boards should work. However, compatibility should be checked when the schematics are released.
Hello! Any update? Now even A311D is out of stock :(
I very much would like to eat the commercial customer who bought your ENTIRE stock! Such a giant ghoul!!!
