I am using a 12V 5A DC power source, and using splitters + a step down converter to power the potato (ubuntu 22, flashed just a few days ago) and a single 4TB SATA hdd. Whenever I reboot, the light on the HDD adapter is showing that there’s power, but I don’t hear the disk spinning (and lsblk doesn’t show the HDD). If I unplug and replug the USB connection, it shows up.
Can you copy and paste your dmesg log into a pastebin?
possibly this line?:
[ 9.858651] usb 1-1.3: USB disconnect, device number 3
Ah, the known issue (mentioned at the end of linked message) with the on-board hub bites another customer.
We plan to fix this by the time we roll out Linux 6.6 soon.
Any update on this? This is recurring issue for me
If you are using Le Potato, use the top port closest to the ethernet. It is not attached to a hub so it does not suffer the reset issue. If it does, it’s a power issue due to your device.
using the top left USB port – also the adapter is powered independently by a 12V 5A adapter – more than enough for one hdd
Please provide your dmesg log or a photo of the screen when the issue occurs.
There are some usb-sata bridges that have broken support for UAS (but they claim to support it, so Linux enables it). The fix is to add a disabling option to the kernel’s boot command line:
usb-storage.quirks=152d:0578:u
The USB ID codes on the right might need adjustment - that was for a common JMicron chip that’s in an enclosure I have. You can find the ID in the output of lsusb (of course the adapter must be attached).
On review, I do see the known issue when onboard-usb-hub (module) is loaded, but that just disconnects the wifi for a moment. What I don’t see any sign of in the dmesg output you pasted was the usb:sata bridge - it’s like it isn’t there during that time. What might be very interesting is a dmesg after the unplug/replug. (just the tail of it with that post-boot activity, mostly). Might be a clue there.
