I’m fairly new to Linux and this is my first experience with an SBC. I have a Le Potato running Ubuntu 22.04.4 LTS with Octoprint for my Ender 3 v2. I followed this guide to get it running:
It seems to work except for the web cam, which I may be asking about later.
In the meantime, I purchased this 7-inch monitor to use with the Le Potato:
https://www.amazon.com/dp/B09ZD8YS7L
When I boot up, output is displayed, but it is very small and nearly unreadable.
It is connected via HDMI. The listed resolution of the screen is 1024 x 600. Is there some setting or file that I can change to make the text bigger or clearer?
Another post mentioned the xrandr command, but that only returns the message, “Can’t open display.” I see one other message on local login that may be related, “usb 1-1.1: 3:1: cannot get freq at ep 0x84.” I don’t see that message when I login via PuTTY.
A review of a similar screen says to, “edit the resolution settings in your /boot/cmdline file to be 800x480 or lower and it works great.” Is there a way to do that with Ubuntu and the Le Potato? If not, is there a different 7" monitor that would work better?
