Hello. I have an Alta board and a HDD USB box connected to it. I write the Debian image for Alta using dd and my laptop. Then connect the HDD Box with the HDD inside it to the USB port of Alta. There is not uSD card or eMMC installed on the device. When I power on the device, it boots and recognizes my HID devices. But it doesn’t boot further. And I can’t use Ctrl+Alt+F2 (or any other function key) to access TTYs.
I’ve noticed the same issue. Any USB device I try to boot the Debian/Raspi Libre images from causes the system-journald to spit out hundreds of lines of errors due to “read-only filesystem”, then the boot process halts. I’m running the current UEFI-BIOS for my Alta and using the recommended 5V power supply from Loverpi.
If you check-out Frank Davis @frankdavis6282 on Youtube, he documents this thoroughly in his 5 of 5 series for the Libre boards where he takes a working microSD card, puts it into a USB reader and tries to boot the Alta from it and it fails. He then takes the same microsd card and boots it from the microSD slot with no issue.
Since this is an S905 board, it’s probably subject to all the weird and wonderful issues that I’ve gradually worked my way past on Potato and Frite. Before we go into those weeds, there is a possible issue with power draw with any external drive. I have some older (MLC era!) SSDs that I can use in an unpowered enclosure, but even laptop HDDs and many more modern SSDs may draw more power than can be reliably delivered through these USB ports, no matter the capacity of the upstream 5V power source.
So you say you’re using a separate power supply, or maybe even tried booting from a lowly flash drive and it still barfs? Join me as I recount my long, strange trip to getting USB booting to work… eventually.
Alright I have done it again and it seems to be the same issue as you @mmaney. The USB device disconnects. However, the problem shouldn’t be with power. It’s only a small USB stick.
This needs to be fixed in the Linux kernel/device tree we use. On startup, the kernel reset the USB hub regulators causing the hub devices to drop off.
Or, if there’s a physical port that’s directly connected to the A311D, my experience with the S805/905 was that the issue only arises when the on-board hub is in the way.
UPDATED So it looks like the Alta’s ports are all connected to the hub. And it’s a different hub chip (well, it would have to be, since it handles USB3). But from some discussion I found on LKML it seems to use the same onboard_usb_hub module, so the same blacklisting might work. Or this hub might need whatever supervision the module provides for $REASONS.
The discussion also says that the developers (not associated with libre?) have only lousy documetation on the chip, which would be my own description of the “product overview” that was all I could find for the GL852 the S805/905 boards use.
Hi, same issue here on the Alta (A311D), usb is disconnecting, reconnecting and in the mean time BTRFS fails. Although it happens as soon as systemd receives a journal log rotation. I also happen to be powering the Alta over USB-A to USB-C cable from my desktop, which should be providing standard USB-A power.
I’ve only connected a Magic Eagle RGB keyboard and my USB storage device which I have no specs on (which is actually 8GB) cuz its branded from a relative’s company.
The lsusb output for the two devices respectively is
Bus 007 Device 003: ID 0c45:7603 Microdia USB Keyboard
Bus 008 Device 004: ID 13fe:6300 Kingston Technology Company Inc. SP Mobile C31 (64GB)
Idk if any of this helps, but I’m gonna change power adapter now and see what happens
I’m a bit confused by this answer as I can’t get a terminal in the machine at all so I’m not sure how to install the latest kernels. I tried using the latest debian 13 arm64 image and I don’t get the BTRFS issue but the installer goes to a black screen after selecting an installation method.
I was able to get the latest Armbian (25.8.1) minimal image to boot off the SSD.
What I didn’t understand is that I could not get anything to boot straight from the SD card, even when reflashing with dist-flash but the bootloader is now working properly with a linux kernel 6.12.41.
There’s no context on what you are doing to understand the issue you are having. There’s multiple images, upstream Debian headless, downstream Libre Computer Debian (no debian 13 yet), Armbian’s Debian, etc.
