I have two Altas w/ eMMC in which I had Debian w/ Gnome installed without issue. I wanted to install as a headless setup so I wiped the eMMC and reinstalled with base Debian 12. Also, I have flashed both with the guide: How to Flash Firmware or Recover Firmware on Libre Computer AML Boards
However, I get stuck when booting in two locations. Obviously, for a headless set up, I need the device to just boot up so I can SSH into them. The device will boot on its own, but it takes like 30 minutes.
First hang is before I get to the UEFI OS menu page. This hang doesn’t last too long (like 2 minutes) or I can press a key and it’ll go to the menu.
The second hang is after I choose the OS in UEFI. The screen goes black. This will hang for 20 minutes or so before moving forward unless I press any key. If I press a key, then I see logs for EFI Stub.
I’ve tried multiple grub configurations but nothing seems to fix. I’ve also reflashed the boot firmware. I’ve tried other OSes including fedora. The issue also occurs when booting from SD card or eMMC.
Any assistance is appreciated. I’m happy to provide logs or screenshots.
Thanks!
