AML-S905D3-CC Solitude gets hot
Hi!
I got my new AML-S905D3-CC Solitude SBC with the Active Cooling Case.
With system load: 2-5%
  • The CPU temp is 55 celsius in the case without the fans used.
  • The CPU temp is 47 celsius without the top of the case.
With full load and top of the case off I get 66 celsius.
Using the fan cools it good, but it is very noisy.
Is 55 celsius high for the board? Or is there a bigger heatsink for the board? Has any body a suggestion?
(I also have an emmc)
Thanks for any answer!
Solitude, non-enclosed, can maintain full performance passively cooled. 55C no air circulation and 66C full load is normal and not hot at all and the chip can work up to 100C.
As a reference, Raspberry Pi boards sit at 66C idle and goes to 85C with just 1 core loaded.
