AML-S905X-CC i2c pull-up resistors missing
I can get i2c-ao and i2c-b enabled but both have terrible waveforms and fail to communicate to devices without external pullups. This is running the latest Ubuntu image.
Raspberry Pi 3B+ has 1.8k external pullups on GPIO2 and GPIO3 which makes I2C work correctly but Le Potato does not according to the schematic and measuring. Am I seeing this correctly? I verified the 60k ohm pullup from the Amlogic S905X is enabled but that’s too weak to run I2C at the 100KHz default frequency.
The schematics are available. These are general purpose IO with multiple functionality. Adding hardware pull ups would limit the other IO functions. If you have a peripheral that needs pull ups, it is recommended to add those to the peripheral.
