AML-S905X-CC (Le Potato) 480x320 ILI9486 3.5" SPI Touchscreen Display
what all do you need for the terminal (i used the dmesg command) and there is, a LOT
heres just ALL of it
pandaboi@lockbox:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.0.12-00858-gb98721ea4575 (autobuild@deb.libre.computer) (gcc (Debian 8.3.0-6) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP PREEMPT_DYNAMIC Thu Dec 8 19:08:19 UTC 2022
[ 0.000000] Machine model: Libre Computer AML-S905X-CC
[ 0.000000] efi: EFI v2.90 by Das U-Boot
[ 0.000000] efi: ESRT=0x7ae51040 RTPROP=0x7ae53040 SMBIOS=0x7ae55000 RNG=0x5787b040 MEMRESERVE=0x5787a040
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] esrt: Reserving ESRT space from 0x000000007ae51040 to 0x000000007ae51078.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000006ac00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000000ffffff]
[ 0.000000] node 0: [mem 0x0000000001000000-0x0000000004ffffff]
[ 0.000000] node 0: [mem 0x0000000005000000-0x00000000072fffff]
[ 0.000000] node 0: [mem 0x0000000007300000-0x000000000fffffff]
[ 0.000000] node 0: [mem 0x0000000010000000-0x00000000101fffff]
[ 0.000000] node 0: [mem 0x0000000010200000-0x000000007ae52fff]
[ 0.000000] node 0: [mem 0x000000007ae53000-0x000000007ae53fff]
[ 0.000000] node 0: [mem 0x000000007ae54000-0x000000007ae54fff]
[ 0.000000] node 0: [mem 0x000000007ae55000-0x000000007ae57fff]
[ 0.000000] node 0: [mem 0x000000007ae58000-0x000000007ae58fff]
[ 0.000000] node 0: [mem 0x000000007ae59000-0x000000007ae5cfff]
[ 0.000000] node 0: [mem 0x000000007ae5d000-0x000000007de7ffff]
[ 0.000000] node 0: [mem 0x000000007de80000-0x000000007de8ffff]
[ 0.000000] node 0: [mem 0x000000007de90000-0x000000007fd97fff]
[ 0.000000] node 0: [mem 0x000000007fd98000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
[ 0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.0.12-00858-gb98721ea4575 root=UUID=21d20927-f521-453e-b2a4-f4285f9554ea ro noquiet splash vt.handoff=7
[ 0.000000] Unknown kernel command line parameters “noquiet splash BOOT_IMAGE=/boot/vmlinuz-6.0.12-00858-gb98721ea4575”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1676076K/2097152K available (14784K kernel code, 1952K rwdata, 6028K rodata, 3712K init, 505K bss, 158932K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Dynamic Preempt: full
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000652] Console: colour dummy device 80x25
[ 0.001172] printk: console [tty0] enabled
[ 0.001213] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.001237] pid_max: default: 32768 minimum: 301
[ 0.001302] LSM: Security Framework initializing
[ 0.001327] Yama: becoming mindful.
[ 0.001447] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001475] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002787] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002829] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002901] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003040] rcu: Hierarchical SRCU implementation.
[ 0.003055] rcu: Max phase no-delay instances is 1000.
[ 0.004300] Remapping and enabling EFI services.
[ 0.004656] smp: Bringing up secondary CPUs …
[ 0.005175] Detected VIPT I-cache on CPU1
[ 0.005308] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005909] Detected VIPT I-cache on CPU2
[ 0.006024] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006590] Detected VIPT I-cache on CPU3
[ 0.006707] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006797] smp: Brought up 1 node, 4 CPUs
[ 0.006866] SMP: Total of 4 processors activated.
[ 0.006878] CPU features: detected: 32-bit EL0 Support
[ 0.006889] CPU features: detected: 32-bit EL1 Support
[ 0.006902] CPU features: detected: CRC32 instructions
[ 0.007375] CPU: All CPU(s) started at EL2
[ 0.007415] alternatives: patching kernel code
[ 0.008813] devtmpfs: initialized
[ 0.014384] Registered cp15_barrier emulation handler
[ 0.014424] Registered setend emulation handler
[ 0.014604] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.014639] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.021511] pinctrl core: initialized pinctrl subsystem
[ 0.021784] regulator-dummy: no parameters, enabled
[ 0.022060] SMBIOS 3.0 present.
[ 0.022091] DMI: libre-computer aml-s905x-cc/aml-s905x-cc, BIOS 2022.07+ 07/01/2022
[ 0.022538] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.023619] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.023916] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.024079] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.024170] audit: initializing netlink subsys (disabled)
[ 0.024400] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[ 0.025600] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.025616] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.025637] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.025899] cpuidle: using governor menu
[ 0.026089] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.026201] ASID allocator initialised with 32768 entries
[ 0.038989] platform c883a000.hdmi-tx: Fixing up cyclic dependency with d0100000.vpu
[ 0.040284] platform cvbs-connector: Fixing up cyclic dependency with d0100000.vpu
[ 0.040757] platform hdmi-connector: Fixing up cyclic dependency with c883a000.hdmi-tx
[ 0.042824] KASLR enabled
[ 0.049658] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.049692] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.049707] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.049720] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.049734] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.049746] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.049761] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.049773] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.116625] raid6: neonx8 gen() 2139 MB/s
[ 0.184688] raid6: neonx4 gen() 2196 MB/s
[ 0.252762] raid6: neonx2 gen() 2085 MB/s
[ 0.320846] raid6: neonx1 gen() 1816 MB/s
[ 0.388904] raid6: int64x8 gen() 1490 MB/s
[ 0.456978] raid6: int64x4 gen() 1663 MB/s
[ 0.525052] raid6: int64x2 gen() 1419 MB/s
[ 0.593125] raid6: int64x1 gen() 1054 MB/s
[ 0.593137] raid6: using algorithm neonx4 gen() 2196 MB/s
[ 0.661185] raid6: … xor() 1582 MB/s, rmw enabled
[ 0.661198] raid6: using neon recovery algorithm
[ 0.661401] fbcon: Taking over console
[ 0.661745] VCC_3V3: 3300 mV, enabled
[ 0.661875] reg-fixed-voltage regulator-vcc_3v3: VCC_3V3 supplying 3300000uV
[ 0.661990] VDDIO_AO18: 1800 mV, enabled
[ 0.662073] reg-fixed-voltage regulator-vddio_ao18: VDDIO_AO18 supplying 1800000uV
[ 0.662172] VDDIO_BOOT: will resolve supply early: vin
[ 0.662180] reg-fixed-voltage regulator-vddio_boot: Looking up vin-supply from device tree
[ 0.662192] VDDIO_BOOT: supplied by VCC_3V3
[ 0.662201] VCC_3V3: could not add device link regulator.3: -ENOENT
[ 0.662256] VDDIO_BOOT: 1800 mV, enabled
[ 0.662340] reg-fixed-voltage regulator-vddio_boot: VDDIO_BOOT supplying 1800000uV
[ 0.662780] iommu: Default domain type: Passthrough
[ 0.663134] SCSI subsystem initialized
[ 0.663301] libata version 3.00 loaded.
[ 0.663521] usbcore: registered new interface driver usbfs
[ 0.663573] usbcore: registered new interface driver hub
[ 0.663612] usbcore: registered new device driver usb
[ 0.663885] pps_core: LinuxPPS API ver. 1 registered
[ 0.663899] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.663924] PTP clock support registered
[ 0.664059] EDAC MC: Ver: 3.0.0
[ 0.664591] Registered efivars operations
[ 0.664964] FPGA manager framework
[ 0.665074] Advanced Linux Sound Architecture Driver Initialized.
[ 0.665687] NetLabel: Initializing
[ 0.665706] NetLabel: domain hash size = 128
[ 0.665717] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.665778] NetLabel: unlabeled traffic allowed by default
[ 0.666218] clocksource: Switched to clocksource arch_sys_counter
[ 0.666443] VFS: Disk quotas dquot_6.6.0
[ 0.666493] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.671905] NET: Registered PF_INET protocol family
[ 0.672085] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.673741] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.673836] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.673865] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.673991] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.674200] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.674466] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.674555] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.674609] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.674773] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.675214] RPC: Registered named UNIX socket transport module.
[ 0.675246] RPC: Registered udp transport module.
[ 0.675257] RPC: Registered tcp transport module.
[ 0.675267] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.675285] NET: Registered PF_XDP protocol family
[ 0.675308] PCI: CLS 0 bytes, default 64
[ 0.675506] Trying to unpack rootfs image as initramfs…
[ 0.687000] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.687570] kvm [1]: IPA Size Limit: 40 bits
[ 0.688862] kvm [1]: vgic interrupt IRQ9
[ 0.689003] kvm [1]: Hyp mode initialized successfully
[ 0.690559] Initialise system trusted keyrings
[ 0.690833] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.696680] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.697340] NFS: Registering the id_resolver key type
[ 0.697396] Key type id_resolver registered
[ 0.697408] Key type id_legacy registered
[ 0.697487] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.697505] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.697690] SGI XFS with ACLs, security attributes, no debug enabled
[ 0.699168] 9p: Installing v9fs 9p2000 file system support
[ 0.736885] xor: measuring software checksum speed
[ 0.740984] 8regs : 2442 MB/sec
[ 0.744941] 32regs : 2522 MB/sec
[ 0.749111] arm64_neon : 2406 MB/sec
[ 0.749151] xor: using function: 32regs (2522 MB/sec)
[ 0.749174] Key type asymmetric registered
[ 0.749187] Asymmetric key parser ‘x509’ registered
[ 0.992503] Freeing initrd memory: 34356K
[ 1.006050] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 1.006168] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.006314] io scheduler mq-deadline registered
[ 1.006335] io scheduler kyber registered
[ 1.006386] io scheduler bfq registered
[ 1.007205] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[ 1.023120] soc soc0: Amlogic Meson GXL (S905X) Revision 21:d (84:2) Detected
[ 1.027309] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.035331] loop: module loaded
[ 1.039654] tun: Universal TUN/TAP device driver, 1.6
[ 1.040681] VFIO - User Level meta-driver version: 0.3
[ 1.041859] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.041892] ehci-pci: EHCI PCI platform driver
[ 1.041936] ehci-platform: EHCI generic platform driver
[ 1.042056] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.042093] ohci-pci: OHCI PCI platform driver
[ 1.042141] ohci-platform: OHCI generic platform driver
[ 1.042584] usbcore: registered new interface driver usb-storage
[ 1.043292] i2c_dev: i2c /dev entries driver
[ 1.047107] sdhci: Secure Digital Host Controller Interface driver
[ 1.047143] sdhci: Copyright(c) Pierre Ossman
[ 1.047536] Synopsys Designware Multimedia Card Interface Driver
[ 1.048073] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.049042] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.050012] meson-sm: secure-monitor enabled
[ 1.050647] hid: raw HID events driver (C) Jiri Kosina
[ 1.050790] usbcore: registered new interface driver usbhid
[ 1.050807] usbhid: USB HID core driver
[ 1.051174] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[ 1.052367] meson-saradc c1108680.adc: Looking up vref-supply from device tree
[ 1.054901] NET: Registered PF_PACKET protocol family
[ 1.055205] 9pnet: Installing 9P2000 support
[ 1.055288] Key type dns_resolver registered
[ 1.055704] registered taskstats version 1
[ 1.055736] Loading compiled-in X.509 certificates
[ 1.058028] zswap: loaded using pool zstd/z3fold
[ 1.059228] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.075584] phy phy-d0078020.phy.0: Looking up phy-supply from device tree
[ 1.075607] phy phy-d0078020.phy.0: Looking up phy-supply property in node /soc/apb@d0000000/phy@78020 failed
[ 1.079210] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 22, base_baud = 1500000) is a meson_uart
[ 2.397545] printk: console [ttyAML0] enabled
[ 2.406626] meson-gx-mmc d0074000.mmc: Looking up vmmc-supply from device tree
[ 2.406823] meson-gx-mmc d0074000.mmc: Looking up vqmmc-supply from device tree
[ 2.407017] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[ 2.407840] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[ 2.428396] HDMI_5V: 5000 mV, enabled
[ 2.428527] reg-fixed-voltage regulator-hdmi-5v: HDMI_5V supplying 5000000uV
[ 2.428754] VCC_CARD: 1800 <–> 3300 mV at 3300 mV, enabled
[ 2.429077] phy phy-d0078000.phy.1: Looking up phy-supply from device tree
[ 2.429095] HDMI_5V: could not add device link phy-d0078000.phy.1: -ENOENT
[ 2.430536] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply from device tree
[ 2.430562] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply property in node /soc/usb@d0078080 failed
[ 2.430753] dwc3-meson-g12a d0078080.usb: USB2 ports: 2
[ 2.430794] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[ 2.446704] meson-gx-mmc d0074000.mmc: no support for card’s volts
[ 2.447256] mmc0: error -22 whilst initialising SDIO card
[ 2.977260] dwc2 c9100000.usb: Looking up vusb_d-supply from device tree
[ 2.977283] dwc2 c9100000.usb: Looking up vusb_d-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.977310] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[ 2.978957] dwc2 c9100000.usb: Looking up vusb_a-supply from device tree
[ 2.978966] dwc2 c9100000.usb: Looking up vusb_a-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.978984] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[ 2.986025] dwc2 c9100000.usb: Looking up vbus-supply from device tree
[ 2.986033] dwc2 c9100000.usb: Looking up vbus-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.986116] dwc2 c9100000.usb: Controller does not support host mode.
[ 2.992301] dwc2: probe of c9100000.usb failed with error -22
[ 3.001492] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.003453] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.011159] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 3.016938] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
[ 3.026295] xhci-hcd xhci-hcd.0.auto: irq 25, io mem 0xc9000000
[ 3.032398] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 3.040320] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.047491] usb usb1: Product: xHCI Host Controller
[ 3.052291] usb usb1: Manufacturer: Linux 6.0.12-00858-gb98721ea4575 xhci-hcd
[ 3.059366] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.064657] hub 1-0:1.0: USB hub found
[ 3.067939] hub 1-0:1.0: 2 ports detected
[ 3.074172] meson-gx-mmc d0072000.mmc: Looking up vmmc-supply from device tree
[ 3.074349] meson-gx-mmc d0072000.mmc: Looking up vqmmc-supply from device tree
[ 3.074502] meson-gx-mmc d0072000.mmc: Got CD GPIO
[ 3.075025] of_cfs_init
[ 3.079143] of_cfs_init: OK
[ 3.082020] ALSA device list:
[ 3.084750] No soundcards found.
[ 3.106864] Freeing unused kernel memory: 3712K
[ 3.107025] Run /init as init process
[ 3.109456] with arguments:
[ 3.109461] /init
[ 3.109466] noquiet
[ 3.109471] splash
[ 3.109475] with environment:
[ 3.109479] HOME=/
[ 3.109484] TERM=linux
[ 3.109488] BOOT_IMAGE=/boot/vmlinuz-6.0.12-00858-gb98721ea4575
[ 3.217540] mmc1: new ultra high speed SDR50 SDXC card at address 5048
[ 3.219258] mmcblk1: mmc1:5048 SD64G 58.0 GiB
[ 3.225577] mmcblk1: p1 p2
[ 3.326305] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 3.349256] BTRFS: device label writable devid 1 transid 640 /dev/mmcblk1p2 scanned by systemd-udevd (169)
[ 3.475844] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 3.478489] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.486474] usb 1-1: Product: USB2.0 Hub
[ 3.542690] mmc0: Card stuck being busy! __mmc_poll_for_busy
[ 3.545077] hub 1-1:1.0: USB hub found
[ 3.546831] hub 1-1:1.0: 4 ports detected
[ 3.569831] [drm] Initialized simpledrm 1.0.0 20200625 for 7fe5b000.framebuffer on minor 0
[ 3.581922] Console: switching to colour frame buffer device 90x36
[ 3.611991] simple-framebuffer 7fe5b000.framebuffer: [drm] fb0: simpledrmdrmfb frame buffer device
[ 3.642589] simple-framebuffer simple-framebuffer.0: [drm] ERROR could not acquire memory range [mem 0x7fd98000-0x7ffeffff flags 0x200]: error -16
[ 3.650813] simple-framebuffer: probe of simple-framebuffer.0 failed with error -16
[ 3.683707] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 3.683730] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 3.686262] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[ 3.687591] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[ 3.687777] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[ 3.695048] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[ 3.700184] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[ 3.707319] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[ 3.713116] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[ 3.714788] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[ 3.714820] meson8b-dwmac c9410000.ethernet: DWMAC1000
[ 3.714827] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[ 3.714833] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[ 3.714838] meson8b-dwmac c9410000.ethernet: COE Type 2
[ 3.714843] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[ 3.714847] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[ 3.715001] meson8b-dwmac c9410000.ethernet: Normal descriptors
[ 3.715008] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[ 3.715012] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.802674] Console: switching to colour dummy device 80x25
[ 3.803098] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[ 3.809118] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[ 3.818349] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[ 3.829592] lima d00c0000.gpu: bus rate = 166666667
[ 3.830076] lima d00c0000.gpu: mod rate = 24000000
[ 3.836143] Trying to free nonexistent resource <000000007fe5b000-000000007ffeffff>
[ 3.844117] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 3.844141] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 3.844176] lima d00c0000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[ 3.865044] [drm] Initialized lima 1.1.0 20191231 for d00c0000.gpu on minor 1
[ 3.878869] meson-dw-hdmi c883a000.hdmi-tx: Looking up hdmi-supply from device tree
[ 3.918538] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 3.925433] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 3.930985] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 3.939392] usb 1-1.1: new full-speed USB device number 3 using xhci-hcd
[ 3.946192] SPI driver ili9486 has no spi_device_id for ozzmaker,piscreen
[ 3.948978] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 2
[ 3.959158] [drm] Initialized ili9486 1.0.0 20200118 for spi0.0 on minor 0
[ 4.040892] usb 1-1.1: New USB device found, idVendor=25a7, idProduct=fa67, bcdDevice= 7.10
[ 4.040929] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.040935] usb 1-1.1: Product: 2.4G Receiver
[ 4.040959] usb 1-1.1: Manufacturer: CX
[ 4.125108] input: CX 2.4G Receiver as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:25A7:FA67.0001/input/input0
[ 4.184176] hid-generic 0003:25A7:FA67.0001: input,hidraw0: USB HID v1.10 Keyboard [CX 2.4G Receiver] on usb-xhci-hcd.0.auto-1.1/input0
[ 4.193207] input: CX 2.4G Receiver Mouse as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:25A7:FA67.0002/input/input1
[ 4.194087] input: CX 2.4G Receiver as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:25A7:FA67.0002/input/input2
[ 4.195277] input: CX 2.4G Receiver Consumer Control as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:25A7:FA67.0002/input/input3
[ 4.254660] input: CX 2.4G Receiver System Control as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:25A7:FA67.0002/input/input4
[ 4.255260] hid-generic 0003:25A7:FA67.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [CX 2.4G Receiver] on usb-xhci-hcd.0.auto-1.1/input1
[ 4.334343] usb 1-1.2: new high-speed USB device number 4 using xhci-hcd
[ 4.436229] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[ 4.436371] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.436455] usb 1-1.2: Product: 802.11n NIC
[ 4.436519] usb 1-1.2: Manufacturer: Realtek
[ 4.436582] usb 1-1.2: SerialNumber: 00E04C0001
[ 5.225329] Console: switching to colour frame buffer device 60x40
[ 5.724846] ili9486 spi0.0: [drm] fb0: ili9486drmfb frame buffer device
[ 5.731527] meson-drm d0100000.vpu: [drm] fb1: mesondrmfb frame buffer device
[ 6.568083] device-mapper: uevent: version 1.0.3
[ 6.569256] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 7.171844] BTRFS info (device mmcblk1p2): using crc32c (crc32c-generic) checksum algorithm
[ 7.174848] BTRFS info (device mmcblk1p2): disk space caching is enabled
[ 7.200711] BTRFS info (device mmcblk1p2): enabling ssd optimizations
[ 7.201601] BTRFS info (device mmcblk1p2): start tree-log replay
[ 8.298411] systemd[1]: System time before build time, advancing clock.
[ 8.384028] NET: Registered PF_INET6 protocol family
[ 8.411526] Segment Routing with IPv6
[ 8.412129] RPL Segment Routing with IPv6
[ 8.414109] In-situ OAM (IOAM) with IPv6
[ 8.485352] systemd[1]: systemd 249.11-0ubuntu3.4 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 8.515118] systemd[1]: Detected architecture arm64.
[ 8.522740] systemd[1]: Hostname set to .
[ 9.274342] systemd[1]: Condition check resulted in Root Slice being skipped.
[ 9.277832] systemd[1]: Condition check resulted in System Slice being skipped.
[ 9.285634] systemd[1]: Queued start job for default target Graphical Interface.
[ 9.324637] systemd[1]: Created slice Slice /system/modprobe.
[ 9.328903] systemd[1]: Created slice Slice /system/serial-getty.
[ 9.336456] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 9.343984] systemd[1]: Created slice Slice /system/systemd-growfs.
[ 9.351064] systemd[1]: Created slice User and Session Slice.
[ 9.357484] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.367372] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.377942] systemd[1]: Reached target Remote File Systems.
[ 9.384793] systemd[1]: Reached target Slice Units.
[ 9.388978] systemd[1]: Reached target Local Verity Protected Volumes.
[ 9.397367] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 9.407462] systemd[1]: Listening on LVM2 poll daemon socket.
[ 9.417096] systemd[1]: Listening on Syslog Socket.
[ 9.423675] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.431816] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.441130] systemd[1]: Listening on Journal Audit Socket.
[ 9.447821] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.455822] systemd[1]: Listening on Journal Socket.
[ 9.466376] systemd[1]: Listening on udev Control Socket.
[ 9.473431] systemd[1]: Listening on udev Kernel Socket.
[ 9.506619] systemd[1]: Mounting Huge Pages File System…
[ 9.515794] systemd[1]: Mounting POSIX Message Queue File System…
[ 9.528222] systemd[1]: Mounting Kernel Debug File System…
[ 9.535944] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.548049] systemd[1]: Starting Journal Service…
[ 9.553868] systemd[1]: Finished Availability of block devices.
[ 9.567326] systemd[1]: Starting Set the console keyboard layout…
[ 9.581052] systemd[1]: Starting Create List of Static Device Nodes…
[ 9.595403] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 9.615774] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 9.633032] systemd[1]: Starting Load Kernel Module configfs…
[ 9.652569] systemd[1]: Starting Load Kernel Module drm…
[ 9.666760] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 9.700300] systemd[1]: Starting Load Kernel Module fuse…
[ 9.718178] systemd[1]: Starting Load Kernel Module mtdpstore…
[ 9.730453] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 9.738450] fuse: init (API version 7.36)
[ 9.743444] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 9.756238] systemd[1]: Starting Load Kernel Module ramoops…
[ 9.768995] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.783568] systemd[1]: Starting Load Kernel Modules…
[ 9.794841] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 9.809210] systemd[1]: Starting Coldplug All udev Devices…
[ 9.839849] systemd[1]: Started Journal Service.
[ 9.844508] BTRFS info (device mmcblk1p2: state M): use zstd compression, level 3
[ 9.863063] IPMI message handler: version 39.2
[ 9.870521] ipmi device interface
[ 10.028956] systemd-journald[443]: Received client request to flush runtime journal.
[ 10.142797] systemd-journald[443]: File /var/log/journal/657e56bbd960423d92a9fe33cce67677/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 10.417660] loop0: detected capacity change from 0 to 121336
[ 10.423592] loop1: detected capacity change from 0 to 118496
[ 10.426342] loop2: detected capacity change from 0 to 8
[ 10.433097] loop3: detected capacity change from 0 to 310088
[ 10.435256] loop4: detected capacity change from 0 to 140280
[ 10.463358] loop5: detected capacity change from 0 to 24032
[ 10.490508] loop6: detected capacity change from 0 to 832
[ 10.509449] loop7: detected capacity change from 0 to 95056
[ 10.513388] loop8: detected capacity change from 0 to 684120
[ 10.523637] loop9: detected capacity change from 0 to 785984
[ 10.543301] loop12: detected capacity change from 0 to 90696
[ 10.543322] loop10: detected capacity change from 0 to 187776
[ 10.544646] loop11: detected capacity change from 0 to 83208
[ 10.548384] loop13: detected capacity change from 0 to 552
[ 11.883170] mc: Linux media interface: v0.10
[ 11.886316] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 11.887816] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 11.897737] videodev: Linux video capture interface: v2.00
[ 11.941476] Registered IR keymap rc-empty
[ 11.943268] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
[ 11.943490] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[ 11.943678] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input6
[ 11.944089] meson-ir c8100580.ir: receiver initialized
[ 11.951509] t9015-codec c8832000.audio-controller: Looking up AVDD-supply from device tree
[ 11.992980] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.001292] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[ 12.001320] SPI driver ads7846 has no spi_device_id for ti,ads7843
[ 12.001326] SPI driver ads7846 has no spi_device_id for ti,ads7845
[ 12.001332] SPI driver ads7846 has no spi_device_id for ti,ads7873
[ 12.285008] ads7846 spi0.1: Looking up vcc-supply from device tree
[ 12.285037] ads7846 spi0.1: Looking up vcc-supply property in node /soc/bus@c1100000/spi@8d80/touchscreen@1 failed
[ 12.285074] ads7846 spi0.1: supply vcc not found, using dummy regulator
[ 12.285613] simple-amplifier analog-amplifier: Looking up VCC-supply from device tree
[ 12.307671] ads7846 spi0.1: touchscreen, irq 47
[ 12.339692] input: ADS7846 Touchscreen as /devices/platform/soc/c1100000.bus/c1108d80.spi/spi_master/spi0/spi0.1/input/input7
[ 12.609611] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.622849] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 12.670485] EEPROM ID = 0x8129
[ 12.887251] usbcore: registered new interface driver r8188eu
[ 13.057962] Adding 1048572k swap on /swapfile. Priority:-2 extents:2 across:2053484k FS
[ 13.585506] r8188eu 1-1.2:1.0 wlx482254dc8693: renamed from wlan0
[ 16.630841] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 16.717539] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 18.149663] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 18.220932] meson8b-dwmac c9410000.ethernet eth0: PHY [mdio_mux-0.e40908ff:08] driver [Meson GXL Internal PHY] (irq=38)
[ 18.231474] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[ 18.231508] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[ 18.232298] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
[ 18.303978] r8188eu 1-1.2:1.0: Firmware Version 11, SubVersion 1, Signature 0x88e1
[ 18.715157] MAC Address = 48:22:54:dc:86:93
[ 20.494530] IPv6: ADDRCONF(NETDEV_CHANGE): wlx482254dc8693: link becomes ready
[ 21.708149] loop14: detected capacity change from 0 to 8
[ 38.554584] rfkill: input handler disabled
[ 51.870727] rfkill: input handler enabled
[ 72.046745] rfkill: input handler disabled
[ 138.121270] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /aliases/spi0
[ 138.125026] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/status
[ 138.135689] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/pinctrl-0
[ 138.147040] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/pinctrl-1
[ 138.158658] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/pinctrl-2
[ 138.169655] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/pinctrl-names
[ 138.180194] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/cs-gpios
[ 143.053452] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c8100000/cec@100/status
[ 143.058691] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/compatible
[ 143.072533] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/reg
[ 143.083700] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/spi-max-frequency
[ 143.096047] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/reset-gpios
[ 143.107243] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/dc-gpios
[ 143.118990] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/display@0/status
[ 143.130697] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/compatible
[ 143.143164] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/pinctrl-names
[ 143.155191] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/pinctrl-0
[ 143.167469] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/reg
[ 143.179174] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/spi-max-frequency
[ 143.192061] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/interrupt-parent
[ 143.206366] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/interrupts
[ 143.217477] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/pendown-gpio
[ 143.229709] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/ti,x-plate-ohms
[ 143.242490] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/ti,pressure-max
[ 143.255215] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/wakeup-source
[ 143.267822] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /soc/bus@c1100000/spi@8d80/touchscreen@1/status
pandaboi@lockbox:~$
had to make an alt so i could reply again. but i got it figured out. the touch now works , but there’s still no display. i used the instructions on the page where i got the screen and tried installing i like you would the raspberry pi. but no luck. any ideas?
Your kernel is out of date. Update it or download the latest images.
Hey, got my mhs3528 working, screen and touch. However, I’ve got a few questions…
  1. Can the screen be used without a GUI? I’d like to boot straight into terminal, and just run PADD on the screen. Right now, if I use raspi-config to change to terminal boot, the screen remains black.
  2. Is this the updated dts and should it be used instead of “spicc-cs1-mhs3528”?
  3. Is the mouse cursor intentionally disabled, and is there a way to re-enable it? I do not plan on using the touchscreen and it is really annoying that it is invisible (EDIT: this might be a VNC issue, not screen issue***)
I am using…
Device1: Le Potato 2GB
Image1: 2023-10-10-raspbian-bookworm-arm64-full+aml-s905x-cc.img
Device2: Le Potato 2GB
Image2: debian-12-base-arm64+aml-s905x-cc.img
Screen: MHS3528 purchased here
I hate to res this topic but thought I would share some info I ran across.
I have a 3.5” amazon screen just like the others in here and using the spicc-cs1-ili9486-xpt2046 overlay on a s905x-cc 2GB model running raspbian bookworm. It worked but screen updates were very laggy to the point it was almost unusable. Touch was also hit or miss because of it.
I changed the spi-max-frequency in the display section of the overlay from 41666667 to 50000000 and it made a world of difference. Not sure if that has any affect on anything else or if it will cause any damage but so far it’s much better.
Just update the kernel to 6.12. It should work at 10+ fps.
Is this also working with Sweet Potato?
This display should work with every one of our boards.
Can you maybe just confirm which display is it excatly? thank you!
We purchased all the screens we could find on Amazon and added it to libretech-wiring-tool. Your model was purchased and integrated.
