Hi every one. Tried the usb burning tool for my s905x le potato board, but burning tool stays on 7% formating, and then i get error [0x32030201]Uboot/Get result/DiskInitial error. If i flash the SD card verion, board boots perfectly. Is there a way from inside android (booted from sd card) to transfer everything on emmc?
Thanks
Double check that your eMMC is connected properly. Make sure you didn’t damage the pins. You can boot to one of our Linux images and make sure the eMMC is properly detected.
OK thanks. will check.
Additionally, check that you have enough power going to the board while flashing. Some USB Type-A ports do not provide the necessary power during the flashing process and it terminates. You can plug in a MicroUSB after inserting the Type-A.
