Board not booting, only red light showing
Hi,
I have an ALL-H3_CC. I downloaded and flashed the correct image from the livre computer website on the sd card. When I boot the computer it only shows a red light and gets no display on the hdmi port. Also, both the orage and yellow lights show on the ethernet port.
There are two variants. ALL-H3-CC-H3 and ALL-H3-CC-H5. They use different images. Make sure you are using the right one.
I’m not sure if I have the h3 or h5 but I have tried both images and the board is still not booting.
I have tried random images and finally found one that boots. Turns out its a Le Potato not a Tritium.
The product is marked on the box as well as the board.
