Both ldto and lgpio do not work on aml-s905x-cc
I’ve had several Le potatoes for a few years and wanted to try to use a power button to shutdown the Le Potato. However, running ‘sudo ldto list’ returns: “No overlays detected. Did you run make?”
Running ‘lgpio headers’ returns: “GPIO map not available for this board.”
I did the fix for the invalid signature and did an apt update and apt upgrade. I tried both the Raspbian and Debian 12 distros from Libre’s distribution center and have the same problem on both. These distros are rather old and the fact that the invalid signature problem still exits shows that they aren’t being maintained. Rasbian hangs alot just now I tried to run the Settings app on Debian an it doesn’t run. I also noticed the firmware files are still missing for the bx2 and bx2x when the initrd is generated,
I tried Armbian’s release for the Le Potato and it works well but I don’t believe the overlays would work. Is there a way to get the the overlay file system and lgpio to work on a Lebre Computer OS on the Le Potato?
The board is booting from the wrong bootloader. You probably have Armbian’s bootloader instead of ours.
