RetroPi : stops at 1. mmcblk1: p1 p2
Ubuntu : Never loads the kernel (30 minute wait time)
Tried latest Lakka : never boots, trying .dtb file fix now but i’m so stumped.
Probably something wrong with one of the following as it’s 99% of the problems:
- Power: make sure your power supply is 5V and 1.5A or higher
- MicroSD card: make sure it can read and write data correctly and passes the Verify step of Win32DiskImager
- Wrong Image: make sure the image is for your board
We go through these step by step.
We don’t support RetroPie anymore. Use Lakka.
I can add to librecomputer’s reply to try a different USB cable as well; I had that issue where the power supply was more than sufficient but I had enough voltage drop over the USB cable itself that the board had similar symptoms to what you’re seeing.
