Would 3.8V be too much for uart pins? I expect so, but thought I would ask anyway, in case I am missing something…
I got a CH340 (maybe actually CH340G) UART TTL module to use with a Le Potato and a Tritium. The Amazon description says 3.3V and 5V modes, but when I tested it, before using it on the boards, its 3.3V mode gave 3.8V. I found another seller which listed 3.3V mode having a range of 3.3-3.8V. I am thinking of returning it due to the description not including the full range and getting another CP2102, instead. (I have one I am using on another board.)
I had heard good things about CH340, and I wanted a different kind in case I find myself in a situation where the CP2102 had some issue. What kinds do you recommend?
This CH340 works fine at about 5V and 3.3-3.8V, but I hesitate to use it with these boards when it can go that much over 3.3V, unless I find they can handle it.
Thanks for any advice.
