Hello,
I have several of these USB devices, the vendor calls them by this name:
DIYmall VK-162 GMOUSE GPS Module
Problem is I can’t get them to work with the AML-S905X-CC using this image fully updated:
2022-09-22-raspbian-bullseye-arm64-lite+aml-s905x-cc.img
The device works on my laptop running Ubuntu 22.04. When I run usb-devices on my laptop, it has this to say about the device:
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#= 7 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=02(commc) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1546 ProdID=01a7 Rev=01.00
S: Manufacturer=u-blox AG - www.u-blox.com
S: Product=u-blox 7 - GPS/GNSS Receiver
C: #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=255ms
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=ff Driver=cdc_acm
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
From the above I can see the Vendor ID is 1546 and the Product ID is 01a7 and the driver is cdc_acm
On the Libre board, when I run usb-devices, the device is not listed at all. I see these messages in dmesg
[279530.834198] usb 1-1.3: new full-speed USB device number 5 using xhci-hcd
[279530.936122] usb 1-1.3: New USB device found, idVendor=1546, idProduct=01a7, bcdDevice= 1.00
[279530.936166] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[279530.936187] usb 1-1.3: Product: u-blox 7 - GPS/GNSS Receiver
[279530.936204] usb 1-1.3: Manufacturer: u-blox AG - www.u-blox.com
[279531.075548] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[279531.075787] usbcore: registered new interface driver cdc_acm
[279531.075806] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[279531.379676] usb 1-1-port3: disabled by hub (EMI?), re-enabling...
[279531.380063] usb 1-1.3: USB disconnect, device number 5
[279531.634253] usb 1-1.3: new full-speed USB device number 6 using xhci-hcd
[279531.942189] usb 1-1.3: new full-speed USB device number 7 using xhci-hcd
[279532.171584] usb 1-1-port3: attempt power cycle
[279532.794173] usb 1-1.3: new full-speed USB device number 9 using xhci-hcd
[279532.794344] usb 1-1.3: Device not responding to setup address.
[279533.002186] usb 1-1.3: device not accepting address 9, error -71
[279533.002807] usb 1-1-port3: unable to enumerate USB device
[281234.514899] usb 1-1.3: new full-speed USB device number 10 using xhci-hcd
[281234.594944] usb 1-1.3: device descriptor read/64, error -71
[281234.782911] usb 1-1.3: new full-speed USB device number 11 using xhci-hcd
[281234.862963] usb 1-1.3: device descriptor read/64, error -71
[281234.971578] usb 1-1-port3: attempt power cycle
[281235.594882] usb 1-1.3: new full-speed USB device number 13 using xhci-hcd
[281235.595061] usb 1-1.3: Device not responding to setup address.
[281235.802886] usb 1-1.3: device not accepting address 13, error -71
[281235.803573] usb 1-1-port3: unable to enumerate USB device
[284480.339630] usb 1-1.3: new full-speed USB device number 14 using xhci-hcd
[284480.419813] usb 1-1.3: Device not responding to setup address.
[284480.627635] usb 1-1.3: device not accepting address 14, error -71
[284480.856897] usb 1-1-port3: attempt power cycle
[284481.479605] usb 1-1.3: new full-speed USB device number 17 using xhci-hcd
[284481.479806] usb 1-1.3: Device not responding to setup address.
[284481.687592] usb 1-1.3: device not accepting address 17, error -71
[284481.688345] usb 1-1-port3: unable to enumerate USB device
[286732.599919] usb 1-1.3: new full-speed USB device number 19 using xhci-hcd
[286732.679961] usb 1-1.3: device descriptor read/64, error -71
[286732.788555] usb 1-1-port3: attempt power cycle
[286733.411914] usb 1-1.3: new full-speed USB device number 21 using xhci-hcd
[286733.412043] usb 1-1.3: Device not responding to setup address.
[286733.619906] usb 1-1.3: device not accepting address 21, error -71
[286733.620558] usb 1-1-port3: unable to enumerate USB device
[334615.242843] usb 1-1-port3: attempt power cycle
[334616.014841] usb 1-1-port3: unable to enumerate USB device
[335337.298024] usb 1-1.3: new full-speed USB device number 26 using xhci-hcd
[335337.378047] usb 1-1.3: device descriptor read/64, error -71
[335337.566018] usb 1-1.3: new full-speed USB device number 27 using xhci-hcd
[335337.646055] usb 1-1.3: device descriptor read/64, error -71
[335337.754620] usb 1-1-port3: attempt power cycle
[335338.527350] usb 1-1-port3: unable to enumerate USB device
It would appear that the OS is trying to use the correct driver, but something is wrong and I’m not entirely sure what.
Things I’ve tried:
unplugging / re-plugging the device.
rebooting
Loading the same driver that my Ubuntu laptop uses:
modprobe cdc_acm
lsmod | grep cdc_acm
cdc_acm 32768 0
Wrote product ID and vendor ID to the driver new_id file per this topic here: linux - Forcing driver to device match - Stack Overflow
echo "1546 01a7" > /sys/bus/usb/drivers/cdc_acm/new_id
After the above steps, I see messages like this from dmesg when I unplug / plug the device:
[ 160.665599] usbcore: registered new interface driver cdc_acm
[ 160.665633] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 161.782389] rc rc1: two consecutive events of type space
[ 266.702302] usb 1-1-port3: attempt power cycle
[ 267.474295] usb 1-1-port3: unable to enumerate USB device
Any help with getting this device working would be very appreciated.
