Hey, having a problem running docker on my RK3328. I currently only have docker-compose running Octoprint. Upon starting docker and immediately using the top command I get:
r
oot@renegade:~# sensors
soc_thermal-virtual-0
Adapter: Virtual device
temp1: +47.3°C (crit = +95.0°C)
root@renegade:~# service start docker
start: unrecognized service
root@renegade:~# service docker start
top
root@renegade:~# top
top - 19:32:08 up 2 min, 1 user, load average: 0.58, 0.51, 0.21
Tasks: 145 total, 2 running, 143 sleeping, 0 stopped, 0 zombie
%Cpu(s): 22.3 us, 4.5 sy, 0.0 ni, 73.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 3973.6 total, 3434.5 free, 211.7 used, 327.5 buff/cache
MiB Swap: 1986.8 total, 1986.8 free, 0.0 used. 3680.9 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3385 root 20 0 262984 35420 8424 R 96.0 0.9 0:02.91 octoprint
3208 root 20 0 9844 3196 2724 R 1.0 0.1 0:00.07 top
3386 systemd+ 20 0 12772 7524 6120 S 1.0 0.2 0:00.03 haproxy
15 root 20 0 0 0 0 I 0.3 0.0 0:00.23 rcu_preempt
207 root 20 0 0 0 0 I 0.3 0.0 0:00.18 kworker/u8:3-writeback
346 root 20 0 0 0 0 I 0.3 0.0 0:00.05 kworker/3:2-mm_percpu_wq
Jumps to 99-103% CPU utilization and then the board locks and needs unplugged/plugged back in (Sometimes red led is stuck on sometimes stuck off). I have passive cooling on the RK chip. Figured I would ask here first before somewhere else because I’ve never had a problem with docker running octoprint on any other SBC’s with docker. I am using the armbian bullseye cli image. I was previously having problems with what I think is my SD card, but I don’t think this would be related. Thanks.
Completely forgot about that, sorry. Unfortunately I am gonna close up on this thread because Ubuntu is now working and I’d much rather use it. More support, and I’m not developing any arm things.
Usually freezing is due to power problems if it suddenly shutdown or freezes. If it stalls certain programs and dies a slow death, then it is usually the MicroSD card. If those two are ruled out, then its the board.
cpuburn stresses the NEON FPU in the chips. You can get it to generate even more heat by running a GPU load and a VPU load simultaneously. 70C is the throttling temperature we set as to not damage the SoC but it is tolerant of much more. Raspberry Pi for examples allows for a maximum of 85C.
I printed an rpi3b case with room for a 40mm fan. Gotta work out how to control a pwm fan now… Currently stable around 40c just running home assistant but was much warmer running with a display attached (60ish). I have it headless now.
I ran the same test with the custom heat sink and as @bigjohnson said, it reaches 70C (and throttles) almost instantly. I’d like to monitor my board to see how often it is throttling; is there a way to monitor the CPU frequency (using raspberry pi os aka raspbian)?
@librecomputer thanks for the quick reply! You’ve solved half of my problem (how to check the CPU frequency). Is there a way to check whether there is thermal throttling?
For anyone following this thread and having trouble finding it, the cpupower utility is not part of the stock raspbian installation; you must install the package linux-cpupower: sudo apt install linux-cpupower. Then you can run cpupower frequency-info to see the current CPU frequency.
All cores run at the same frequency.
