New to the SBC world. Brand new AML-S905X-CC Le Potato, 2GB.
SD card inserted & flashed with Debian 12 from here. Download was decompressed and then flashed to the SD card using dd on macOS.
The board is connected via a USB-UART adaptor to the UART header. No other connections to the board.
On power up the red and blue LEDs light - steady on, neither one flickering, no signs of power brown-outs evident.
The terminal shows the following output:
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:0;RCY:0;USB:0;SPI:0;CHK:A7;EMMC:400;NAND:81;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 1699345
BL2 Built : 15:21:18, Aug 28 2019. gxl g1bf2b53 - luan.yuan@droid15-sz
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 912MHz
bist_test rank: 0 18 00 31 2b 15 41 16 00 2c 30 19 47 18 01 2f 2b 14 43 19 03 30 2b 13 43 693
rank: 1 19 04 2f 2c 15 43 16 00 2d 31 18 4a 17 03 2c 2b 16 41 19 04 2f 2b 13 43 693 - PASS
Rank0: 1024MB(auto)-2T-13
Rank1: 1024MB(auto)-2T-13
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x0001b800, part: 0
Load bl33 from SD, src: 0x0003c200, des: 0x01000000, size: 0x00086600, part: 0
aml log : SIG CHK : 231 for address 0x01000000
Firmware load fail! reset...
reset...
And repeats this boot loop indefinitely.
How does one get past this error?
Is it correct to assume that the board never even attempts to load the OS?
Many thanks.
