Hello, I am having trouble with the GenBasic WiFi 4 USB Nanos that I ordered from LoveRPI. Their website description indicated it would be plug-n-play. I bought these to provide WLAN for AML-S905X-CC running Debian (bullseye) aarch 64. I reached out to get help from LoveRPI directly but they referred me to post here.
_,met$$$$$gg.
,g$$$$$$$$$$$$$$$P. --------------------
,g$$P" """Y$$.". OS: Debian GNU/Linux 11 (bullseye) aarch64
,$$P' `$$$. Host: aml-s905x-cc
',$$P ,ggs. `$$b: Kernel: 6.1.24-05037-g3d3785f9a49e
`d$$' ,$P"' . $$$ Uptime: 1 day, 23 hours, 31 mins
$$P d$' , $$P Packages: 1459 (dpkg)
$$: $$. - ,d$$' Shell: zsh 5.8
$$; Y$b._ _,d$P' Resolution: 720x576i
Y$$. `.`"Y$$$$P"' Terminal: /dev/pts/0
`$$b "-.__ CPU: (4) @ 1.512GHz
`Y$$ Memory: 896MiB / 1961MiB
`Y$$.
`$$b.
`Y$$b.
`"Y$b._
Without any changes to the kernel or kernel modules, the WLAN comes up for a few minutes but constantly resets. Output from dmesg below. I searched for solutions via Google and found several instances suggesting patch/recomplile for the kernel driver was needed – but I bought these modules specifically from LoveRPI because they were suggested to be plug n’ play w/ upstream drivers… Are these units defective? Thanks in advance for your help.
[170365.793233] usb 1-1.3: new high-speed USB device number 4 using xhci-hcd
[170366.025310] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[170366.025397] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[170366.025437] usb 1-1.3: Product: 802.11 n WLAN
[170366.025470] usb 1-1.3: SerialNumber: 1.0
[170366.131564] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[170366.157306] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[170366.180287] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[170366.293694] usb 1-1.3: reset high-speed USB device number 4 using xhci-hcd
[170366.396011] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[170366.398420] mt7601u 1-1.3:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[170366.860015] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[170367.146218] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[170367.152133] usbcore: registered new interface driver mt7601u
[170372.333160] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.333622] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.333662] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.333811] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.333851] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.333999] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.334031] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.334177] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.334207] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.334342] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.349214] mt7601u 1-1.3:1.0: Error: MCU response pre-completed!
[170372.349612] mt7601u 1-1.3:1.0: Error: send MCU cmd failed:-71
[170372.436345] usb 1-1.3: USB disconnect, device number 4
[170372.757089] usb 1-1.3: new high-speed USB device number 5 using xhci-hcd
[170372.987570] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[170372.987657] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[170372.987697] usb 1-1.3: Product: 802.11 n WLAN
[170372.987731] usb 1-1.3: SerialNumber: 1.0
[170373.076064] usb 1-1.3: reset high-speed USB device number 5 using xhci-hcd
[170373.184332] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[170373.185342] mt7601u 1-1.3:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[170373.642878] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[170373.830439] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[170373.830611] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:4-3!
[170373.830911] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[170373.831008] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:4-3!
[170373.831299] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[170373.831394] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:4-3!
[170373.831682] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[170373.831776] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:4-3!
[170373.831902] mt7601u 1-1.3:1.0: Error: MCU resp urb failed:-71
[170373.832153] mt7601u 1-1.3:1.0: Error: MCU resp evt:0 seq:4-3!
[170373.832248] mt7601u 1-1.3:1.0: Error: mt7601u_mcu_wait_resp timed out
[170373.993469] mt7601u 1-1.3:1.0: Vendor request req:07 off:0080 failed:-71
[170374.153115] mt7601u 1-1.3:1.0: Vendor request req:02 off:0080 failed:-71
[170374.313464] mt7601u 1-1.3:1.0: Vendor request req:02 off:0080 failed:-71
[170374.313822] mt7601u: probe of 1-1.3:1.0 failed with error -110
[170374.318977] usb 1-1.3: USB disconnect, device number 5
[170374.549067] usb 1-1.3: new high-speed USB device number 6 using xhci-hcd
[170374.779818] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[170374.780008] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[170374.780108] usb 1-1.3: Product: 802.11 n WLAN
[170374.780191] usb 1-1.3: SerialNumber: 1.0
[170374.872325] usb 1-1.3: reset high-speed USB device number 6 using xhci-hcd
[170374.980254] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[170374.985833] mt7601u 1-1.3:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[170375.436387] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[170375.715294] ieee80211 phy2: Selected rate control algorithm 'minstrel_ht'
[170735.700836] usb 1-1.3: USB disconnect, device number 6
[170735.738748] mt7601u 1-1.3:1.0: Warning: TX DMA did not stop!
[170739.742556] mt7601u 1-1.3:1.0: Warning: MAC TX did not stop!
[170742.146273] mt7601u 1-1.3:1.0: Warning: MAC RX did not stop!
[170742.146339] mt7601u 1-1.3:1.0: Warning: RX DMA did not stop!
[170742.458209] usb 1-1.3: new high-speed USB device number 7 using xhci-hcd
[170742.688793] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[170742.688981] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[170742.689081] usb 1-1.3: Product: 802.11 n WLAN
[170742.689163] usb 1-1.3: SerialNumber: 1.0
[170742.777326] usb 1-1.3: reset high-speed USB device number 7 using xhci-hcd
[170742.883647] mt7601u 1-1.3:1.0: ASIC revision: 76010001 MAC revision: 76010500
[170742.885257] mt7601u 1-1.3:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[170743.332635] mt7601u 1-1.3:1.0: EEPROM ver:0c fae:00
[170743.611707] ieee80211 phy3: Selected rate control algorithm 'minstrel_ht'
