HDMI suddenly stopped working
I am currently using a Le Potato running Lakka 6.1, and i was able to use it just fine, however now the computer boots up (steady red and green lights, with flashing blue light), oddly, when i boot up rasbian on a different SD card everything including HDMI works perfectly, i have tried lakka on both cards yet the Hdmi still does not work, the only thing that i did was that once when the computer was shut down, i swapped the lakka sd card with the rasbian sd card, then i put the lakka card back in and suddenly the hdmi stopped working, one time the hdmi suddenly started working, however it was scaled weirdly and had weird grainy red diagonal lines spanning across the entire monitor, and now it is back to not working. what could be causing this?
well now i swapped the power supply and lakka starts to boot, however the screen eventually mostly gets covered by red shimmering dots, and all 3 lights stay on steadily, (the blue one stops blinking), it is weird because the previous power supply worked fine, I am at a complete loss, can someone help?
For Lakka issues, we cannot help because they use a different custom Linux than we do. You need to post on the Lakka forum.
this happens with rasbian too now
