I got the le potato as a pi alternative and I was trying to run the RFM9x adafruit library in python.
I was using the code here LoRa Raspberry Pi Setup | LoRa and LoRaWAN Radio for Raspberry Pi | Adafruit Learning System
It’s just a small script so see if the board is detecting the radio via spi. When I tried to run the script it says " DigitalInOut(board.D5)
AttributeError: board has no attribute ‘D5’ "
Essentially it’s trying to set the pin D5 on the pi to input but it can’t find that on this board. I tried to use the wiring-tool to find the equivalent pin ref but it still says board doesn’t have attribute.
