La Frite AML-S805X-AC not booting and with UART message Firmware load fail!
I started using my La Frite AML-S805X-AC again. It has been dormant for a few month with no power.
After providing it with power it did not show any image on my monitor.
Curious way it did not boot I conneted my TTL232 to it and sag that it was stuck
in a loop, showing the following message over and over again, see below.
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 11
CPU clk: 1200MHz
DDR enable rdbi
DDR use ext vref
DDR ZQ power down
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0 16bit @ 1200MHz
bist_test rank: 0 10 00 20 26 13 39 12 00 24 26 14 39 1d 1d 1d 1d 1d 1d 1c 1c 1c 1c 1c 1c 730
Rank0: 1024MB(auto)-2T-18
AddrBus test pass!
Set ddr ssc: ppm1000-
Load fip header from SPI, src: 0x0000c000, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from SPI, src: 0x00010000, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from SPI, src: 0x00020000, des: 0x05100000, size: 0x0002b400, part: 0
aml log : SIG CHK : 231 for address 0x05100000
Firmware load fail! reset...
reset...
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:1;RCY:0;SPI:0;0.0;CHK:0;
TE: 35044
BL2 Built : 15:21:18, Aug 28 2019. gxl g1bf2b53 - luan.yuan@droid15-sz
power supply is a stabiles 5v 3A adapter
flashed 2x Sandisk drives, each with one of the 2 images
aml-s805x-ac-spiflash.img
libre-computer-aml-s805x-ac-debian-buster-xfce-mali-4.19.64±2019-08-05.img
unfortunately it will not boot from usb.
I also provided it with power over USB_A-to-USB_A cable while holding the u-boot button. This only gave the following line with no other option and no image on my monitor.
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:0;RCY:0;USB:0;
Any help and suggestion would be much appriciated.
Where did you get the unit? The software on the SPI NOR was corrupted.
To be honest, I do not remember. It have been approximately over 1,5 year.
I never heard of SPI NOR, is there a way to bring it back to life?
What can I do to make it work again?
any chance someone can help with this issue?
It would be greatly appreciated.
