I’ve got a fresh install of 2022-09-22-raspbian-bullseye-arm64-lite+aml-s905x-cc and then run sudo apt update; sudo apt full-upgrade. I can’t seem to get the CPU clock to vary? It is stuck at 1.5GHz (with some very brief dips to 1.2GHz). This is running nothing, load of 0.03.
$sudo cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
ondemand
$sudo cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
1500000
I’ve tried it both with HDMI and headless, in case it was the monitor resolution causing the clock speed, but they both give the same result. Am I reading the CPU clock speed wrong, or is there a bug?
I also noticed there are no conservative or powersave governors available, which would be better for my use case (battery powered).
Thank you
