The goal is to add an MQTT server via docker and a MYSQL database via docker. Currently NexcloudPi is running on Le Potato via docker.
Is there a good set of instructions to arrive at the goal? When Googling how to do something, should I treat LePotato as if it were a rPI4?
Treat Le Potato like a standard PC. Follow standard Ubuntu instructions.
I am trying to install an MQTT broker per these instructions:
https://www.schaerens.ch/raspi-setting-up-mosquitto-mqtt-broker-on-raspberry-pi-docker/
docker ps returns:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
docker-compose up -d. returns:
bash: docker-compose: command not found
Do I need to reinstall docker?
Thanks for the reply. per your instructions, I will explore using the Ubuntu OS instead of Raspian.
Please advise why Ubuntu is recommended over Raspbian? Thank you
Apparently, I missed this step:
sudo apt-get install libffi-dev libssl-dev python3-dev python3 python3-pip -y
sudo pip3 install docker-compose
Ubuntu runs standard 64-bit ARMv8 userspace. Raspbian runs a slower compatibility userspace for older ARM architectures (ARMv6) so it is slower.
