My Le Potato is only glowing red, everything else is turned off, I’m using Armbian_23.5.1_Lepotato_jammy_current_6.1.30.img.xz on my Lexar mirco 32GB SD card, I booted the raspbian-11-bullseye before but never had this problem, is their a way to reset the board for it shows the blue led and red
Did you decompress the .xz file so you were writing the .img file?
Also the Win32 Imager worked more consistently for me than the RPi imager.
If the blue light does not light up without any device other than the power supply attached, it means that the LED is broken or the SoC was short circuited.
so its broken, can I fix it??
