Folks,
Running image:
2023-10-10-raspbian-bookworm-arm64-lite+aml-s905x-cc.img.xz
Le Potato. I notice after followed through the instruction and enable ssh by placing the blank ssh file on the SD card after got done making the SD card.
Powered on the first time, Le Potato is pingable but could not SSH to it. Power cycled then SSH is working as it should. This behavior can be repeat, I have tried that 3 time. They were the same everytime (1st powered up = no SSH, 2nd powered up = SSH is working).
Also, after 2nd power up and SSH in to the Le Potato I noticed sshswitch.service had failed. Not sure how to resolve. Does it even use it? Could I just disable the sshswitch.service because it does not appear to do anything?
