Libre Computer AML-S905X-CC Le Potato Tinymembench Benchmark
tinymembench v0.4.9 (simple benchmark for memory throughput and latency)
== Memory bandwidth tests                                               ==
== Note 1: 1MB = 1000000 bytes                                          ==
== Note 2: Results for 'copy' tests show how many bytes can be          ==
==         copied per second (adding together read and writen           ==
==         bytes would have provided twice higher numbers)              ==
== Note 3: 2-pass copy means that we are using a small temporary buffer ==
==         to first fetch data into it, and only then write it to the   ==
==         destination (source -> L1 cache, L1 cache -> destination)    ==
== Note 4: If sample standard deviation exceeds 0.1%, it is shown in    ==
==         brackets                                                     ==
 C copy backwards                                     :   2084.8 MB/s (1.4%)
 C copy backwards (32 byte blocks)                    :   2077.7 MB/s (1.0%)
 C copy backwards (64 byte blocks)                    :   2120.8 MB/s (1.7%)
 C copy                                               :   2160.7 MB/s (2.0%)
 C copy prefetched (32 bytes step)                    :   1567.8 MB/s (0.8%)
 C copy prefetched (64 bytes step)                    :   1676.1 MB/s (0.1%)
 C 2-pass copy                                        :   1661.0 MB/s
 C 2-pass copy prefetched (32 bytes step)             :    994.4 MB/s
 C 2-pass copy prefetched (64 bytes step)             :   1397.5 MB/s
 C fill                                               :   5846.3 MB/s
 C fill (shuffle within 16 byte blocks)               :   5847.8 MB/s
 C fill (shuffle within 32 byte blocks)               :   5846.9 MB/s
 C fill (shuffle within 64 byte blocks)               :   5846.4 MB/s
 standard memcpy                                      :   2232.0 MB/s (0.4%)
 standard memset                                      :   5854.1 MB/s
 NEON LDP/STP copy                                    :   2232.4 MB/s
 NEON LDP/STP copy pldl2strm (32 bytes step)          :   1305.4 MB/s (0.6%)
 NEON LDP/STP copy pldl2strm (64 bytes step)          :   1902.3 MB/s (0.5%)
 NEON LDP/STP copy pldl1keep (32 bytes step)          :   2628.7 MB/s
 NEON LDP/STP copy pldl1keep (64 bytes step)          :   2644.5 MB/s
 NEON LD1/ST1 copy                                    :   2183.3 MB/s (0.6%)
 NEON STP fill                                        :   5842.7 MB/s
 NEON STNP fill                                       :   5791.7 MB/s (0.1%)
 ARM LDP/STP copy                                     :   2234.7 MB/s (0.1%)
 ARM STP fill                                         :   5848.6 MB/s
 ARM STNP fill                                        :   5781.1 MB/s
== Memory latency test                                                  ==
== Average time is measured for random memory accesses in the buffers   ==
== of different sizes. The larger is the buffer, the more significant   ==
== are relative contributions of TLB, L1/L2 cache misses and SDRAM      ==
== accesses. For extremely large buffer sizes we are expecting to see   ==
== page table walk with several requests to SDRAM for almost every      ==
== memory access (though 64MiB is not nearly large enough to experience ==
== this effect to its fullest).                                         ==
== Note 1: All the numbers are representing extra time, which needs to  ==
==         be added to L1 cache latency. The cycle timings for L1 cache ==
==         latency can be usually found in the processor documentation. ==
== Note 2: Dual random read means that we are simultaneously performing ==
==         two independent memory accesses at a time. In the case if    ==
==         the memory subsystem can't handle multiple outstanding       ==
==         requests, dual random read has the same timings as two       ==
==         single reads performed one after another.                    ==
block size : single random read / dual random read, [MADV_NOHUGEPAGE]
      1024 :    0.0 ns          /     0.0 ns
      2048 :    0.0 ns          /     0.0 ns
      4096 :    0.0 ns          /     0.0 ns
      8192 :    0.0 ns          /     0.0 ns
     16384 :    0.0 ns          /     0.0 ns
     32768 :    0.0 ns          /     0.0 ns
     65536 :    4.1 ns          /     7.5 ns
    131072 :    6.4 ns          /    10.7 ns
    262144 :    8.2 ns          /    13.5 ns
    524288 :   86.2 ns          /   136.7 ns
   1048576 :  137.1 ns          /   185.2 ns
   2097152 :  164.9 ns          /   202.1 ns
   4194304 :  179.2 ns          /   208.4 ns
   8388608 :  186.1 ns          /   211.3 ns
  16777216 :  189.5 ns          /   212.9 ns
  33554432 :  191.4 ns          /   214.0 ns
  67108864 :  201.0 ns          /   232.5 ns
block size : single random read / dual random read, [MADV_HUGEPAGE]
     65536 :    4.1 ns          /     7.3 ns
    131072 :    6.3 ns          /    10.9 ns
    262144 :    8.1 ns          /    13.4 ns
    524288 :   86.1 ns          /   136.8 ns
   1048576 :  137.0 ns          /   185.2 ns
   2097152 :  164.0 ns          /   201.3 ns
   4194304 :  177.8 ns          /   207.1 ns
   8388608 :  184.8 ns          /   209.4 ns
  16777216 :  188.4 ns          /   210.5 ns
  33554432 :  190.0 ns          /   211.0 ns
  67108864 :  190.9 ns          /   211.1 ns
