This board has not been released. It’s not possible for you to have purchased it.
I received my purchase and it is a v1 board. I made an assumption that was incorrect.
Thank you for your prompt response.
Thanks for the quick reply and sorry for the delay on my part (had to dig up a serial adapter to get the logs).
Fair enough. What would be the easiest way to reenable it? My own build of U-Boot? I could presumably add it to boot_targets but it seems I can’t save the environment:
=> saveenv
Saving Environment to FAT... Card did not respond to voltage select! : -110
** Bad device specification mmc 0 **
Failed (1)
This seems to only happen in certain circumstances but I’m not quite sure what. Perhaps it’s the attempted tftp without an ipaddr set first.
=> setenv serverip 192.168.0.1
=> tftpboot
Speed: 100, full duplex
*** ERROR: `ipaddr' not set
=> setenv ipaddr 192.168.0.199
=> tftpboot
*** Warning: no boot file name; using 'C0A800C7.img'
Using ethernet@c9410000 device
TFTP from server 192.168.0.1; our IP address is 192.168.0.199
Filename 'C0A800C7.img'.
Load address: 0x1000000
Loading: *
TFTP error: 'File not found' (1)
Not retrying...
=> pxe get
missing environment variable: pxeuuid
Filename 'pxelinux.cfg/default-arm-meson-aml-s805x-ac'.
Load address: 0x1080000
Loading: *
Not retrying...
Retrieving file: pxelinux.cfg/default-arm-meson
Filename 'pxelinux.cfg/default-arm-meson'.
Loading: UDP wrong checksum 0000000a 00009e02
T UDP wrong checksum 0000000a 00009e02
T T UDP wrong checksum 0000000a 00009e02
T T T T UDP wrong checksum 0000000a 00009e02
T T T
Retry count exceeded; starting again
Filename 'pxelinux.cfg/default-arm'.
Loading: *
Not retrying...
From a power-on reset, if I set the serverip and boot target to pxe, it works:
GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:1;RCY:0;SPI:0;0.0;CHK:0;
TE: 35045
BL2 Built : 15:21:18, Aug 28 2019. gxl g1bf2b53 - luan.yuan@droid15-sz
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 11
CPU clk: 1200MHz
DDR enable rdbi
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0 16bit @ 1080MHz
bist_test rank: 0 17 00 2f 2d 1a 41 17 00 2f 2d 19 41 23 23 23 24 24 24 23 23 23 23 23 23 643
Rank0: 1024MB(auto)-2T-18
AddrBus test pass!
Set ddr ssc: ppm1000-
Load fip header from SPI, src: 0x0000c000, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from SPI, src: 0x00010000, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from SPI, src: 0x00020000, des: 0x05100000, size: 0x0001b800, part: 0
Load bl33 from SPI, src: 0x0003c000, des: 0x01000000, size: 0x00094200, part: 0
NOTICE: BL31: v1.3(release):c3714b49be
NOTICE: BL31: Built : 09:23:36, Jun 20 2023. gxl bl-3.5.0 gc3714b49be - jenkins@walle02-sh
NOTICE: BL3-1: GXL normal boot!
NOTICE: BL31: BL33 decompress pass
mpu_config_enable:system pre init ok
OPS=0x34
dmc sec lock
[Image: gxl_v1.1.3509-d977ed20a4 2023-06-20 09:43:46 jenkins@walle02-sh]
21 0d 34 00 bf fe 3e 53 5b 00 26 ca 06 8f 10 02
[0.756439 Inits done]
secure task start!
high task start!
low task start!
ERROR: Error initializing runtime service opteed_fast
U-Boot 2023.07+ (May 15 2024 - 23:35:02 -0400) Libre Computer AML-S805X-AC
Model: Libre Computer AML-S805X-AC
SoC: Amlogic Meson GXL (S805X) Revision 21:d (34:2)
DRAM: 512 MiB (effective 1 GiB)
Core: 177 devices, 33 uclasses, devicetree: separate
WDT: Not starting watchdog@98d0
MMC: mmc@74000: 0
Loading Environment from FAT... Card did not respond to voltage select! : -110
Couldn't find partition mmc 0
Error: could not access storage.
[BL31]: tee size: 0
[BL31]: tee size: 0
Net: eth0: ethernet@c9410000
starting USB...
Bus usb@c9000000: dwc3_meson_gxl_get_phys: usb2 ports: 2
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@c9000000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Seq Method State Uclass Part Name Filename
Scanning global bootmeth 'efi_mgr':
Scanning bootdev 'mmc@74000.bootdev':
No more bootdevs
(0 bootflows, 0 valid)
=> setenv boot_targets pxe
=> boot
BOOTP broadcast 1
DHCP client bound to address 192.168.0.49 (3 ms)
Scanning bootdev 'ethernet@c9410000.bootdev':
Retrieving file: pxelinux.cfg/01-42-50-73-68-14-46
TFTP from server 192.168.0.1; our IP address is 192.168.0.49
Filename 'pxelinux.cfg/01-42-50-73-68-14-46'.
Loading: ################################################## 446 Bytes
13.7 KiB/s
done
Bytes transferred = 446 (1be hex)
0 pxe ready ethernet 0 ethernet@c9410000.bootdev extlinux/extlinux.conf
** Booting bootflow 'ethernet@c9410000.bootdev.0' with pxe
In the meantime, I’ve done this. I had to remove CONFIG_BOOTP_SERVERIP=y from configs/libretech-ac_defconfig and add pxe or dhcp back to BOOT_TARGETS in include/configs/meson64.h.
The description doesn’t say when this update is needed or what it does.
I think this update is a u-boot update that is only used if the system has already been configured to boot with a spi-flash device that is attached to the spi pins. (I.e. not needed if booting from SD Card or eMMC).
Is this correct?
No, it’s configured to be bootable even if SPI NOR is empty as long as it’s on a proper bootable device that the SoC checks like MicroSD or eMMC.
I have a Renegade. I’m using the download images from the Libre web site as available today (August 20, 2024)
roc-rk3328-cc-spiflash is 24MB and dated October 13, 2023.
Are those images complete and up-to-date or is this boot update still needed?
It looks like this is ‘raw’ code that self-executes and updates the lowest level boot loader binary? I.e. not u-boot.
Why is it called “spi-flash”? Are there any release notes that say what this update does?
ROC-RK3328-CC does not have SPI NOR. The bootloader has to be part of the image per the OP. That is an internal test image from our CI infrastructure. Hence the CI in the URL.
Get images from www.libre.computer Download section or use libretech-flash-tool.
2024-11-15 15:49:49 root@lepotato:~# libretech-flash-tool
libretech-flash-tool: command not found
2024-11-15 15:49:59 root@lepotato:~#
Is there supposed to be an extra package installed? (this is raspbian12 image)
Edit: nevermind, I see this is a whole project GitHub - libre-computer-project/libretech-flash-tool
2024-11-15 16:00:14 root@lepotato:~# git clone https://github.com/libre-computer-project/libretech-flash-tool.git
Cloning into 'libretech-flash-tool'...
remote: Enumerating objects: 266, done.
remote: Counting objects: 100% (266/266), done.
remote: Compressing objects: 100% (181/181), done.
remote: Total 266 (delta 135), reused 208 (delta 78), pack-reused 0 (from 0)
Receiving objects: 100% (266/266), 634.51 KiB | 309.00 KiB/s, done.
Resolving deltas: 100% (135/135), done.
2024-11-15 16:02:12 root@lepotato:~# cd libretech-flash-tool
total 16K
drwxr-xr-x 1 root root 70 2024-11-15 16:02 .
drwx------ 1 root root 234 2024-11-15 16:02 ..
-rwxr-xr-x 1 root root 669 2024-11-15 16:02 diff.sh
drwxr-xr-x 1 root root 138 2024-11-15 16:02 .git
-rwxr-xr-x 1 root root 4.5K 2024-11-15 16:02 lft.sh
drwxr-xr-x 1 root root 160 2024-11-15 16:02 lib
-rw-r--r-- 1 root root 2.3K 2024-11-15 16:02 readme.md
drwxr-xr-x 1 root root 16 2024-11-15 16:02 vendor
2024-11-15 16:02:22 root@lepotato:~/libretech-flash-tool# ./lft.sh board-list
all-h3-cc-h3
all-h3-cc-h5
aml-a311d-cc-v01
aml-a311d-cc
aml-s805x-ac
aml-s905x-cc
aml-s905x-cc-v2
aml-s905d-pc
aml-s905d3-cc-v01
aml-s905d3-cc
roc-rk3328-cc
roc-rk3328-cc-v2
roc-rk3399-pc
2024-11-15 16:02:32 root@lepotato:~/libretech-flash-tool# ./lft.sh dev-list
mmcblk0boot0
mmcblk0boot1
zram0
2024-11-15 16:02:55 root@lepotato:~/libretech-flash-tool#
Am I supposed to choose mmblk0boot0 or mmcblk0boot1 ?
By default, it does not show the boot device that / (root) is mounted to. You need to force it.
mmcblk0 force
I have the Renegade Elite ROC-RK3399-PC from the original indiegogo campaign. I can successfully flash my microsd card with Balena Etcher on Windows, but it does not boot. There is also no boot switch on the board, only a recovery button to go into Mask ROM mode.
How do I flash the ROC-RK3399-PC SPI?? Please help, thanks!
-Dan
It’s possibile for aml-s905x-cc-v2 create custom uboot firmware? I need implement gpio-keys for keypower so I think edit uboot dts
ex add:
gpio-keys {
compatible = "gpio-keys";
power-button {
label = "power";
gpios = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_LOW>;
linux,code = <KEY_POWER>;
wakeup-source;
and create implment inside u-boot my meson_board_late_init function for wait trigger pulse button for continue boot.
This is because I like to put 5V to my board but not autopower but only if I press button (as atx pc).
I see the schematics but sweet potato v2 board not expose KEY_PWR pin from pmic that used for this case usually
LAG
There’s no need to modify the built-in firmware. The boards default firmware support an override DT path. Just modify the override path to include the gpio-keys for power key binding.
I use yocto so fitImage (built with uboot 2023.07+) in eemc partition boot will be match as uboot otherwise stuck at boot. So DTB is custom in uboot and in kernel-space.
Because recently I buy another two sweet potato after flash emmc the os not boot correctly.
When Investigate i found latest firmware installed to spi.
I would like to know how create mycustom bootloader (slider to mmc) and leave spi method or how to downgrade spi (firmware) bootloader to 2023.07+
LAG
There’s an on-board switch that disables the SPI bootloader and cause the board to try to load from eMMC and SD card. There’s no need to modify the onboard bootloader.
I think board try to load uboot. Need only u-boot.bin or any others files!?
LAG
u-boot.bin from u-boot is not enough. You need to sign it and load the DDR bits. You can use this tool: GitHub - libre-computer-project/libretech-builder-simple
DO NOT USE THIS FOR LA FRITE (possibly Kickstarter version-specific) - IT WILL BRICK YOUR BOARD AS OTHERS HAVE REPORTED. Recovery will NOT work as they claim in other posts.
TAKE DOWN THIS LINK AND REMOVE THESE INSTRUCTIONS FOR LA-FRITE TO STOP MORE BOARDS FROM BEING RUINED PLEASE!
The board cannot be physically bricked. You just need to press the button and flash the SPI NOR again.
