Thank you!
I wonder why it didn’t come up through the search I ran…
Having issues with the boot loader. I have tried flashing it to a couple of different SD cards on different versions of linux. They all say they are successful but when i put it into my potato it doesn’t boot. Swap it for a SD the has distro a image and it boots fine. The temp file that is downloaded is 784k compared to 832k shown in the git instructions. everything else matches the guide
I’m running into an issue where my ubuntu installation will not boot until a press the enter key a few times - this is even with the hdmi disconnected or as a headless unit (already setup ssh). I was planning to flash using this tool but my rok-3328-cc shows dev-list as having mmcblk0boot0 and mmcblk80boot1. Which do I select?
If your Ubuntu installation will not boot, it means that the keyboard you are using might be sending keypresses on enumeration. Switch keyboards and check whether it will boot. The keyboard is should not send keystrokes on enumeration but some cheap ones do not have proper controllers.
@librecomputer
How can this RPI IMAGE FILE be modified to boot on this board:
Libre Computer Le Potato AML-S905X-CC
