tinymembench v0.4.9 (simple benchmark for memory throughput and latency)
== Memory bandwidth tests                                               ==
== Note 1: 1MB = 1000000 bytes                                          ==
== Note 2: Results for 'copy' tests show how many bytes can be          ==
==         copied per second (adding together read and writen           ==
==         bytes would have provided twice higher numbers)              ==
== Note 3: 2-pass copy means that we are using a small temporary buffer ==
==         to first fetch data into it, and only then write it to the   ==
==         destination (source -> L1 cache, L1 cache -> destination)    ==
== Note 4: If sample standard deviation exceeds 0.1%, it is shown in    ==
==         brackets                                                     ==
 C copy backwards                                     :  12744.3 MB/s (0.7%)
 C copy backwards (32 byte blocks)                    :  12732.3 MB/s (0.8%)
 C copy backwards (64 byte blocks)                    :  12730.6 MB/s (0.6%)
 C copy                                               :  12749.2 MB/s (0.5%)
 C copy prefetched (32 bytes step)                    :  12756.8 MB/s (0.5%)
 C copy prefetched (64 bytes step)                    :  12768.9 MB/s (0.5%)
 C 2-pass copy                                        :  11952.6 MB/s (0.4%)
 C 2-pass copy prefetched (32 bytes step)             :  11523.8 MB/s (0.4%)
 C 2-pass copy prefetched (64 bytes step)             :  11625.2 MB/s (0.3%)
 C fill                                               :  18651.2 MB/s (0.3%)
 C fill (shuffle within 16 byte blocks)               :  18651.6 MB/s (0.3%)
 C fill (shuffle within 32 byte blocks)               :  18660.0 MB/s (0.3%)
 C fill (shuffle within 64 byte blocks)               :  18643.3 MB/s (0.2%)
 standard memcpy                                      :  12625.4 MB/s (0.6%)
 standard memset                                      :  18663.2 MB/s (0.3%)
 NEON LDP/STP copy                                    :  12593.5 MB/s (0.8%)
 NEON LDP/STP copy pldl2strm (32 bytes step)          :  12664.4 MB/s (0.5%)
 NEON LDP/STP copy pldl2strm (64 bytes step)          :  12620.4 MB/s (0.6%)
 NEON LDP/STP copy pldl1keep (32 bytes step)          :  12386.0 MB/s (0.8%)
 NEON LDP/STP copy pldl1keep (64 bytes step)          :  12260.9 MB/s (0.5%)
 NEON LD1/ST1 copy                                    :  12260.9 MB/s (0.4%)
 NEON STP fill                                        :  18639.6 MB/s (0.3%)
 NEON STNP fill                                       :  18650.1 MB/s (0.3%)
 ARM LDP/STP copy                                     :  12479.4 MB/s (0.6%)
 ARM STP fill                                         :  18622.6 MB/s (0.3%)
 ARM STNP fill                                        :  18624.6 MB/s (0.4%)
== Memory latency test                                                  ==
== Average time is measured for random memory accesses in the buffers   ==
== of different sizes. The larger is the buffer, the more significant   ==
== are relative contributions of TLB, L1/L2 cache misses and SDRAM      ==
== accesses. For extremely large buffer sizes we are expecting to see   ==
== page table walk with several requests to SDRAM for almost every      ==
== memory access (though 64MiB is not nearly large enough to experience ==
== this effect to its fullest).                                         ==
== Note 1: All the numbers are representing extra time, which needs to  ==
==         be added to L1 cache latency. The cycle timings for L1 cache ==
==         latency can be usually found in the processor documentation. ==
== Note 2: Dual random read means that we are simultaneously performing ==
==         two independent memory accesses at a time. In the case if    ==
==         the memory subsystem can't handle multiple outstanding       ==
==         requests, dual random read has the same timings as two       ==
==         single reads performed one after another.                    ==
block size : single random read / dual random read, [MADV_NOHUGEPAGE]
      1024 :    0.0 ns          /     0.0 ns
      2048 :    0.0 ns          /     0.0 ns
      4096 :    0.0 ns          /     0.0 ns
      8192 :    0.0 ns          /     0.0 ns
     16384 :    0.0 ns          /     0.0 ns
     32768 :    0.0 ns          /     0.0 ns
     65536 :    0.0 ns          /     0.0 ns
    131072 :    0.9 ns          /     1.2 ns
    262144 :    3.3 ns          /     4.7 ns
    524288 :    9.2 ns          /    12.7 ns
   1048576 :   12.8 ns          /    15.6 ns
   2097152 :   24.9 ns          /    35.2 ns
   4194304 :   74.2 ns          /   104.0 ns
   8388608 :  106.1 ns          /   131.5 ns
  16777216 :  128.2 ns          /   144.8 ns
  33554432 :  141.8 ns          /   152.8 ns
  67108864 :  155.8 ns          /   163.1 ns
block size : single random read / dual random read, [MADV_HUGEPAGE]
    262144 :    2.7 ns          /     3.6 ns
    524288 :    8.0 ns          /    11.5 ns
   2097152 :   20.5 ns          /    26.8 ns
   4194304 :   73.2 ns          /   103.3 ns
   8388608 :  106.0 ns          /   130.6 ns
  16777216 :  125.7 ns          /   142.8 ns
  33554432 :  136.2 ns          /   148.0 ns
  67108864 :  144.1 ns          /   152.1 ns
            Mongoose? What is the context of this test?
