Need help with why software image may not be working
I am trying to install OpenAuto from Bluewave Studio. It boots up with normal raspberry pi os but for some reason it does not work on this board and I have no idea why. Is there any big differences between the Libre and Pi that could cause it not to boot. I just can’t seem to figure out why it is not working.
The website says it comes preinstalled on an image for a raspberry pi, which definitely will not be compatible. Raspberry Pi and Le Potato use different SOC’s, so you can’t just pop a Pi image in your Potato like that.
If there’s some way to install it over a preexisting Raspbian OS, then maybe you can get it to work with one of Libre Computer’s images (https://www.libre.computer/downloads/aml-s905x-cc/)
I’d inquire here:
https://bluewavestudio.io/community/
Also, I didn’t look in to it very far, but this software doesn’t seem to be as open as the name would suggest. I would suggest they change the name to “ProprietaryAuto”. Just a little pet peeve of mine.
Ah, ok that is the answer I was looking for. I didn’t know the difference between Pi and Le Potato. thank you for that.
