No HDMI, ROC-RK3328-CC
Hi!
I was looking forward to running my graphical application on the renegade, but now that I’m trying to start the computer, there is no HDMI output at all. I have followed the instructions, and this is the UART trace that I get:
PMIC:  RK8050 (on=0x40, off=0x00)
DDR4, 800MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
Trying to boot from BOOTROM
Returning to boot ROM...
Trying to boot from MMC1
lz4 image
NOTICE:  BL31: v2.9(release):v2.8-1351-g8929dffc0
NOTICE:  BL31: Built : 16:23:24, Oct 13 2023
NOTICE:  BL31:Rockchip release version: v1.2
U-Boot 2023.07+ (Oct 13 2023 - 16:23:26 -0400) Libre Computer ROC-RK3328-CC
DRAM:  4 GiB
Core:  244 devices, 31 uclasses, devicetree: separate
MMC:   mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from FAT... Unable to read "uboot.env" from mmc1:1...
Error (-2): cannot determine file size
failed to probe rk hdmi
Model: Libre Computer ROC-RK3328-CC
starting USB...
Bus usb@ff5c0000: USB EHCI 1.00
Bus usb@ff5d0000: USB OHCI 1.0
Bus usb@ff600000: generic_phy_get_bulk : no phys property
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@ff580000: USB DWC2
scanning bus usb@ff5c0000 for devices... 1 USB Device(s) found
scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found
scanning bus usb@ff600000 for devices... 1 USB Device(s) found
scanning bus usb@ff580000 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot:  1  0
Seq  Method       State   Uclass    Part  Name                      Filename
Scanning global bootmeth 'efi_mgr':
Scanning bootdev 'mmc@ff520000.bootdev':
Scanning bootdev 'mmc@ff500000.bootdev':
  0  efi          ready   mmc          1  mmc@ff500000.bootdev.part efi/boot/bootaa64.efi
** Booting bootflow 'mmc@ff500000.bootdev.part_1' with efi
Failed to load EFI variables
Welcome to GRUB!
error: no suitable video mode found.
error: no video mode activated.
GNU GRUB  version 2.06-13+deb12u1
As you can see, there are multiple “failed to probe rk hdmi” uboot messages and finally “no video mode” errors from GRUB. Other than that, the board seems to be working fine, but sadly no video output makes it useless in my case. This particular run was done with the debian-12-gnome-arm64+roc-rk3328-cc.img, although I guess the particual image makes no difference. Do you have any advice that could help? Or is it true then that the boards have hardware issues regarding HDMI? I have two of them, and will test the other one tomorrow.
In such these cases, always try another image and see if it works. Also, have you verified signature of the image you’ve downloaded?
I’ve tried debian/ubuntu base/gui images on suggested SD cards. Checksums are correct. The operating system runs. But the “failed hdmi probes” seem to originate earlier in the boot process. There isn’t anything regarding uboot that I could do/check? The other renegade board behaves exactly the same :frowning:
Rockchip’s u-boot HDMI support was in rough shape in 2023. We will refresh the firmware for RK3328 and RK3399 soon with much improved HDMI support.
Any updates on the firmware?
