OpenClaw Setup Prompt Guide for Libre Computer
OpenClaw can be installed via EtherealOS by first deploying upstream Debian base image and then running the OpenClaw installer.
After you have setup the basic system and connected OpenClaw to a model, we recommend the following prompt to complete basic system setup. Please note that these are tested against Claude and may have different results on other models.
Configure the OpenClaw host system:
1. **Disk:** Expand root partition to use full available disk space and add a 2GB swap if DRAM is < 2GB
2. **Voice Transcription:**
  - Install faster-whisper
  - Auto-select model based on RAM:
    - >4GB: small model
    - >2GB (≤4GB): base model
    - ≤2GB: tiny model
  - Configure OpenClaw to use selected model for speech to text
  - Test with TTS-generated voice clip (not noise)
3. **Access:**
  - Enable gateway.controlUi.allowInsecureAuth = true
  - Set up nginx reverse proxy with self-signed SSL for HTTPS access
4. **System Monitoring**
  - Create health check script to monitor:
    - OOM kills
    - disk space utilization >85%
    - free memory <10%
    - high load
    - failed services
    - agent model failure
  - Schedule every 15 minutes via cron
  - Alert user via the first configured channel of any problems
