Is there a supported or recommended partition edit tool for the RK3328? I’m trying to set up a dual boot on a single SD card with LibreElec and Lakka to use as a home entertainment center. My intended method would be:
- Flash the bootloader to a blank SD card
- Flash the two OSes to two separate USB’s
- Flash a partition editing tool to a third USB
- Boot to the partition edit tool and write the two OSes from the USBs to the SD
Is this even possible or viable?
