PoE hat for Cottonwood boards
Hi — will there ever be another run of the PoE hats made for the Alta and Solitude boards? Or are there alternative hats that can be used?
If the boards use a standard 40-pin header, a generic 802.3af/at PoE hat is worth a look, but check two things first: whether the header pinout matches and whether the hat delivers the voltage the board expects (many output 5V only). Isolation and the PoE negotiation type also vary between hats, so a module that matches the header pin-for-pin is safer than one that just physically fits.
