hello i was looking at the AML-S905X-CC-V1.0A Headers spreadsheet to figure out the numbers of some gpio pins and i noticed that pin 26 is green on the spreadsheet and blue on my board. just wanted to make this aware to someone
this is the spreadsheet i found in case its the wrong one
There is no error. That is a GPIO with no hardware channel select. From the 40P RPi compatible header, it is used as a channel select. From the hardware level, it is a GPIO.
