Potato ethernet not working after update - Ubuntu 22.04.02 LTS {solved}
I recently updated my Potato that I used to use for pihole, but now only use occasionally as an SFTP server or other basic tasks. Networking was broken and I have so far been unsuccessful understanding why I cant get the link up through normal means. Attached below is the shell history from the remote machine I performed the update with. I am now, of course, debugging locally.
PS C:\Users\User1> ssh ubuntu@192.168.0.14
Enter passphrase for key 'C:\Users\User1/.ssh/id_rsa':
Last login: Tue Apr 18 12:24:29 2023 from 192.168.0.10
ubuntu@pihole1:~$ sudo apt update
Hit:1 https://deb.libre.computer/repo linux InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Get:3 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease [119 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease [108 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease [110 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 Packages [917 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main Translation-en [216 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 c-n-f Metadata [13.7 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports jammy-updates/restricted arm64 Packages [389 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages [789 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 c-n-f Metadata [15.9 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports jammy-updates/multiverse arm64 Packages [12.4 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 Packages [663 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 c-n-f Metadata [8736 B]
Get:15 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages [603 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 c-n-f Metadata [11.6 kB]
Fetched 3977 kB in 16s (254 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
36 packages can be upgraded. Run 'apt list --upgradable' to see them.
ubuntu@pihole1:~$ sudo apt upgrade
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  libopenexr25 libpostproc55 libmagickcore-6.q16-6-extra libavcodec58
  libmagickwand-6.q16-6 libavutil56 libswscale5 libmagickcore-6.q16-6
  libswresample3 imagemagick-6-common libavformat58 libavfilter7
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following NEW packages will be installed:
  linux-headers-6.1.24-05037-g3d3785f9a49e linux-image-6.1.24-05037-g3d3785f9a49e
The following packages have been kept back:
  apt apt-utils libapt-pkg6.0
The following packages will be upgraded:
  alsa-ucm-conf bind9-dnsutils bind9-host bind9-libs distro-info-data dnsutils grub-efi-arm64 grub-efi-arm64-bin
  grub-efi-arm64-signed libldap-2.5-0 libldap-common libllvm15 libnss-systemd libpam-systemd libpulse0 libsystemd0
  libudev1 linux-headers-lc-stable-arm64 linux-image-lc-stable-arm64 python3-tz systemd systemd-sysv systemd-timesyncd
  ubuntu-advantage-tools udev vim vim-common vim-runtime vim-tiny xserver-common xserver-xorg-core xserver-xorg-legacy
  xxd
33 upgraded, 2 newly installed, 0 to remove and 3 not upgraded.
5 standard LTS security updates
Need to get 85.6 MB of archives.
After this operation, 196 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://deb.libre.computer/repo linux/main arm64 linux-headers-6.1.24-05037-g3d3785f9a49e arm64 6.1.24-05037-g3d3785f9a49e-1 [8271 kB]
Get:2 https://deb.libre.computer/repo linux/main arm64 linux-headers-lc-stable-arm64 arm64 6.1.24-05037-g3d3785f9a49e-1 [1680 B]
Get:3 https://deb.libre.computer/repo linux/main arm64 linux-image-6.1.24-05037-g3d3785f9a49e arm64 6.1.24-05037-g3d3785f9a49e-1 [30.5 MB]
Get:4 https://deb.libre.computer/repo linux/main arm64 linux-image-lc-stable-arm64 arm64 6.1.24-05037-g3d3785f9a49e-1 [1680 B]
Get:5 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libnss-systemd arm64 249.11-0ubuntu3.9 [133 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 xserver-common all 2:21.1.4-2ubuntu1.7~22.04.1 [28.0 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 xserver-xorg-legacy arm64 2:21.1.4-2ubuntu1.7~22.04.1 [34.5 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libsystemd0 arm64 249.11-0ubuntu3.9 [314 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 xserver-xorg-core arm64 2:21.1.4-2ubuntu1.7~22.04.1 [1447 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 systemd-timesyncd arm64 249.11-0ubuntu3.9 [29.9 kB]Get:11 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 systemd-sysv arm64 249.11-0ubuntu3.9 [10.5 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libpam-systemd arm64 249.11-0ubuntu3.9 [205 kB]
Get:13 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 systemd arm64 249.11-0ubuntu3.9 [4421 kB]
Get:14 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 udev arm64 249.11-0ubuntu3.9 [1541 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libudev1 arm64 249.11-0ubuntu3.9 [74.9 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 distro-info-data all 0.52ubuntu0.3 [5258 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 ubuntu-advantage-tools arm64 27.14.4~22.04 [171 kB]Get:18 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 vim arm64 2:8.2.3995-1ubuntu2.7 [1664 kB]
Get:19 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 vim-tiny arm64 2:8.2.3995-1ubuntu2.7 [677 kB]
Get:20 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 vim-runtime all 2:8.2.3995-1ubuntu2.7 [6825 kB]
Get:21 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 xxd arm64 2:8.2.3995-1ubuntu2.7 [53.2 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports jammy-security/main arm64 vim-common all 2:8.2.3995-1ubuntu2.7 [81.5 kB]
Get:23 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 bind9-host arm64 1:9.18.12-0ubuntu0.22.04.1 [51.9 kB]
Get:24 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 bind9-dnsutils arm64 1:9.18.12-0ubuntu0.22.04.1 [158 kB]
Get:25 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 bind9-libs arm64 1:9.18.12-0ubuntu0.22.04.1 [1199 kB]
Get:26 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 alsa-ucm-conf all 1.2.6.3-1ubuntu1.5 [41.7 kB]
Get:27 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 dnsutils all 1:9.18.12-0ubuntu0.22.04.1 [3924 B]
Get:28 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 grub-efi-arm64-signed arm64 1.187.3~22.04.1+2.06-2ubuntu14.1 [1402 kB]
Get:29 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 grub-efi-arm64 arm64 2.06-2ubuntu14.1 [47.0 kB]
Get:30 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 grub-efi-arm64-bin arm64 2.06-2ubuntu14.1 [1496 kB]Get:31 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libldap-2.5-0 arm64 2.5.14+dfsg-0ubuntu0.22.04.2 [181 kB]
Get:32 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libldap-common all 2.5.14+dfsg-0ubuntu0.22.04.2 [15.8 kB]
Get:33 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libllvm15 arm64 1:15.0.7-0ubuntu0.22.04.1 [24.2 MB]Get:34 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 libpulse0 arm64 1:15.99.1+dfsg1-1ubuntu2.1 [264 kB]Get:35 http://ports.ubuntu.com/ubuntu-ports jammy-updates/main arm64 python3-tz all 2022.1-1ubuntu0.22.04.1 [30.7 kB]
Fetched 85.6 MB in 6min 50s (209 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
setting xserver-xorg-legacy/xwrapper/allowed_users from configuration file
(Reading database ... 93802 files and directories currently installed.)
Preparing to unpack .../libnss-systemd_249.11-0ubuntu3.9_arm64.deb ...
Unpacking libnss-systemd:arm64 (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../xserver-common_2%3a21.1.4-2ubuntu1.7~22.04.1_all.deb ...
Unpacking xserver-common (2:21.1.4-2ubuntu1.7~22.04.1) over (2:21.1.3-2ubuntu2.9) ...
Preparing to unpack .../xserver-xorg-legacy_2%3a21.1.4-2ubuntu1.7~22.04.1_arm64.deb ...
Unpacking xserver-xorg-legacy (2:21.1.4-2ubuntu1.7~22.04.1) over (2:21.1.3-2ubuntu2.9) ...
Preparing to unpack .../libsystemd0_249.11-0ubuntu3.9_arm64.deb ...
Unpacking libsystemd0:arm64 (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Setting up libsystemd0:arm64 (249.11-0ubuntu3.9) ...
Preparing to unpack .../0-xserver-xorg-core_2%3a21.1.4-2ubuntu1.7~22.04.1_arm64.deb ...
Unpacking xserver-xorg-core (2:21.1.4-2ubuntu1.7~22.04.1) over (2:21.1.3-2ubuntu2.9) ...
Preparing to unpack .../1-systemd-timesyncd_249.11-0ubuntu3.9_arm64.deb ...
Unpacking systemd-timesyncd (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../2-systemd-sysv_249.11-0ubuntu3.9_arm64.deb ...
Unpacking systemd-sysv (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../3-libpam-systemd_249.11-0ubuntu3.9_arm64.deb ...
Unpacking libpam-systemd:arm64 (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../4-systemd_249.11-0ubuntu3.9_arm64.deb ...
Unpacking systemd (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../5-udev_249.11-0ubuntu3.9_arm64.deb ...
Unpacking udev (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Preparing to unpack .../6-libudev1_249.11-0ubuntu3.9_arm64.deb ...
Unpacking libudev1:arm64 (249.11-0ubuntu3.9) over (249.11-0ubuntu3.7) ...
Setting up libudev1:arm64 (249.11-0ubuntu3.9) ...
Preparing to unpack .../00-distro-info-data_0.52ubuntu0.3_all.deb ...
Unpacking distro-info-data (0.52ubuntu0.3) over (0.52ubuntu0.2) ...
Preparing to unpack .../01-ubuntu-advantage-tools_27.14.4~22.04_arm64.deb ...
Unpacking ubuntu-advantage-tools (27.14.4~22.04) over (27.13.6~22.04.1) ...
Preparing to unpack .../02-vim_2%3a8.2.3995-1ubuntu2.7_arm64.deb ...
Unpacking vim (2:8.2.3995-1ubuntu2.7) over (2:8.2.3995-1ubuntu2.5) ...
Preparing to unpack .../03-vim-tiny_2%3a8.2.3995-1ubuntu2.7_arm64.deb ...
Unpacking vim-tiny (2:8.2.3995-1ubuntu2.7) over (2:8.2.3995-1ubuntu2.5) ...
Preparing to unpack .../04-vim-runtime_2%3a8.2.3995-1ubuntu2.7_all.deb ...
Unpacking vim-runtime (2:8.2.3995-1ubuntu2.7) over (2:8.2.3995-1ubuntu2.5) ...
Preparing to unpack .../05-xxd_2%3a8.2.3995-1ubuntu2.7_arm64.deb ...
Unpacking xxd (2:8.2.3995-1ubuntu2.7) over (2:8.2.3995-1ubuntu2.5) ...
Preparing to unpack .../06-vim-common_2%3a8.2.3995-1ubuntu2.7_all.deb ...
Unpacking vim-common (2:8.2.3995-1ubuntu2.7) over (2:8.2.3995-1ubuntu2.5) ...
Preparing to unpack .../07-bind9-host_1%3a9.18.12-0ubuntu0.22.04.1_arm64.deb ...
Unpacking bind9-host (1:9.18.12-0ubuntu0.22.04.1) over (1:9.18.1-1ubuntu1.3) ...
Preparing to unpack .../08-bind9-dnsutils_1%3a9.18.12-0ubuntu0.22.04.1_arm64.deb ...
Unpacking bind9-dnsutils (1:9.18.12-0ubuntu0.22.04.1) over (1:9.18.1-1ubuntu1.3) ...
Preparing to unpack .../09-bind9-libs_1%3a9.18.12-0ubuntu0.22.04.1_arm64.deb ...
Unpacking bind9-libs:arm64 (1:9.18.12-0ubuntu0.22.04.1) over (1:9.18.1-1ubuntu1.3) ...
Preparing to unpack .../10-alsa-ucm-conf_1.2.6.3-1ubuntu1.5_all.deb ...
Unpacking alsa-ucm-conf (1.2.6.3-1ubuntu1.5) over (1.2.6.3-1ubuntu1.4) ...
Preparing to unpack .../11-dnsutils_1%3a9.18.12-0ubuntu0.22.04.1_all.deb ...
Unpacking dnsutils (1:9.18.12-0ubuntu0.22.04.1) over (1:9.18.1-1ubuntu1.3) ...
Preparing to unpack .../12-grub-efi-arm64-signed_1.187.3~22.04.1+2.06-2ubuntu14.1_arm64.deb ...
Unpacking grub-efi-arm64-signed (1.187.3~22.04.1+2.06-2ubuntu14.1) over (1.182~22.04.1+2.06-2ubuntu10) ...
Preparing to unpack .../13-grub-efi-arm64_2.06-2ubuntu14.1_arm64.deb ...
Unpacking grub-efi-arm64 (2.06-2ubuntu14.1) over (2.06-2ubuntu10) ...
Preparing to unpack .../14-grub-efi-arm64-bin_2.06-2ubuntu14.1_arm64.deb ...
Unpacking grub-efi-arm64-bin (2.06-2ubuntu14.1) over (2.06-2ubuntu10) ...
Preparing to unpack .../15-libldap-2.5-0_2.5.14+dfsg-0ubuntu0.22.04.2_arm64.deb ...
Unpacking libldap-2.5-0:arm64 (2.5.14+dfsg-0ubuntu0.22.04.2) over (2.5.14+dfsg-0ubuntu0.22.04.1) ...
Preparing to unpack .../16-libldap-common_2.5.14+dfsg-0ubuntu0.22.04.2_all.deb ...
Unpacking libldap-common (2.5.14+dfsg-0ubuntu0.22.04.2) over (2.5.14+dfsg-0ubuntu0.22.04.1) ...
Preparing to unpack .../17-libllvm15_1%3a15.0.7-0ubuntu0.22.04.1_arm64.deb ...
Unpacking libllvm15:arm64 (1:15.0.7-0ubuntu0.22.04.1) over (1:15.0.6-3~ubuntu0.22.04.2) ...
Preparing to unpack .../18-libpulse0_1%3a15.99.1+dfsg1-1ubuntu2.1_arm64.deb ...
Unpacking libpulse0:arm64 (1:15.99.1+dfsg1-1ubuntu2.1) over (1:15.99.1+dfsg1-1ubuntu2) ...
Selecting previously unselected package linux-headers-6.1.24-05037-g3d3785f9a49e.
Preparing to unpack .../19-linux-headers-6.1.24-05037-g3d3785f9a49e_6.1.24-05037-g3d3785f9a49e-1_arm64.deb ...
Unpacking linux-headers-6.1.24-05037-g3d3785f9a49e (6.1.24-05037-g3d3785f9a49e-1) ...
Preparing to unpack .../20-linux-headers-lc-stable-arm64_6.1.24-05037-g3d3785f9a49e-1_arm64.deb ...
Unpacking linux-headers-lc-stable-arm64 (6.1.24-05037-g3d3785f9a49e-1) over (6.0.19-02543-g73f2949c2dd9-1) ...
Selecting previously unselected package linux-image-6.1.24-05037-g3d3785f9a49e.
Preparing to unpack .../21-linux-image-6.1.24-05037-g3d3785f9a49e_6.1.24-05037-g3d3785f9a49e-1_arm64.deb ...
Unpacking linux-image-6.1.24-05037-g3d3785f9a49e (6.1.24-05037-g3d3785f9a49e-1) ...
Preparing to unpack .../22-linux-image-lc-stable-arm64_6.1.24-05037-g3d3785f9a49e-1_arm64.deb ...
Unpacking linux-image-lc-stable-arm64 (6.1.24-05037-g3d3785f9a49e-1) over (6.0.19-02543-g73f2949c2dd9-1) ...
Preparing to unpack .../23-python3-tz_2022.1-1ubuntu0.22.04.1_all.deb ...
Unpacking python3-tz (2022.1-1ubuntu0.22.04.1) over (2022.1-1ubuntu0.22.04.0) ...
Setting up linux-image-6.1.24-05037-g3d3785f9a49e (6.1.24-05037-g3d3785f9a49e-1) ...
 * dkms: running auto installation service for kernel 6.1.24-05037-g3d3785f9a49e                                 [ OK ]
update-initramfs: Generating /boot/initrd.img-6.1.24-05037-g3d3785f9a49e
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/50-cloudimg-settings.cfg'
Sourcing file `/etc/default/grub.d/60-libre-computer-settings.cfg'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.1.24-05037-g3d3785f9a49e
Found initrd image: /boot/initrd.img-6.1.24-05037-g3d3785f9a49e
Found linux image: /boot/vmlinuz-6.0.19-02543-g73f2949c2dd9
Found initrd image: /boot/initrd.img-6.0.19-02543-g73f2949c2dd9
Found linux image: /boot/vmlinuz-6.0.19-02540-g29b5aaf3e447
Found initrd image: /boot/initrd.img-6.0.19-02540-g29b5aaf3e447
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
Setting up bind9-libs:arm64 (1:9.18.12-0ubuntu0.22.04.1) ...
Setting up alsa-ucm-conf (1.2.6.3-1ubuntu1.5) ...
Setting up libpulse0:arm64 (1:15.99.1+dfsg1-1ubuntu2.1) ...
Setting up distro-info-data (0.52ubuntu0.3) ...
Setting up systemd (249.11-0ubuntu3.9) ...
Setting up libldap-common (2.5.14+dfsg-0ubuntu0.22.04.2) ...
Setting up libldap-2.5-0:arm64 (2.5.14+dfsg-0ubuntu0.22.04.2) ...
Setting up xxd (2:8.2.3995-1ubuntu2.7) ...
Setting up python3-tz (2022.1-1ubuntu0.22.04.1) ...
Setting up vim-common (2:8.2.3995-1ubuntu2.7) ...
Setting up systemd-timesyncd (249.11-0ubuntu3.9) ...
Setting up udev (249.11-0ubuntu3.9) ...
Setting up grub-efi-arm64-bin (2.06-2ubuntu14.1) ...
Setting up linux-headers-6.1.24-05037-g3d3785f9a49e (6.1.24-05037-g3d3785f9a49e-1) ...
Setting up libllvm15:arm64 (1:15.0.7-0ubuntu0.22.04.1) ...
Setting up ubuntu-advantage-tools (27.14.4~22.04) ...
Installing new version of config file /etc/apt/apt.conf.d/20apt-esm-hook.conf ...
Installing new version of config file /etc/ubuntu-advantage/uaclient.conf ...
Installing new version of config file /etc/update-motd.d/91-contract-ua-esm-status ...
Removing obsolete conffile /etc/update-motd.d/88-esm-announce ...
Setting up xserver-common (2:21.1.4-2ubuntu1.7~22.04.1) ...
Setting up linux-headers-lc-stable-arm64 (6.1.24-05037-g3d3785f9a49e-1) ...
Setting up vim-runtime (2:8.2.3995-1ubuntu2.7) ...
Setting up bind9-host (1:9.18.12-0ubuntu0.22.04.1) ...
Setting up xserver-xorg-legacy (2:21.1.4-2ubuntu1.7~22.04.1) ...
Setting up linux-image-lc-stable-arm64 (6.1.24-05037-g3d3785f9a49e-1) ...
Setting up systemd-sysv (249.11-0ubuntu3.9) ...
Setting up grub-efi-arm64 (2.06-2ubuntu14.1) ...
Installing grub to /boot/firmware.
Installing for arm64-efi platform.
grub-install: warning: EFI variables cannot be set on this system.
grub-install: warning: You will have to complete the GRUB setup manually.
Installation finished. No error reported.
done
Setting up vim (2:8.2.3995-1ubuntu2.7) ...
Setting up grub-efi-arm64-signed (1.187.3~22.04.1+2.06-2ubuntu14.1) ...
Setting up xserver-xorg-core (2:21.1.4-2ubuntu1.7~22.04.1) ...
Setting up libnss-systemd:arm64 (249.11-0ubuntu3.9) ...
Setting up vim-tiny (2:8.2.3995-1ubuntu2.7) ...
Setting up libpam-systemd:arm64 (249.11-0ubuntu3.9) ...
Setting up bind9-dnsutils (1:9.18.12-0ubuntu0.22.04.1) ...
Setting up dnsutils (1:9.18.12-0ubuntu0.22.04.1) ...
Processing triggers for dbus (1.12.20-2ubuntu4.1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Processing triggers for initramfs-tools (0.140ubuntu13.1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
Processing triggers for man-db (2.10.2-1) ...
Fetched 337 kB in 6s (54.7 kB/s)
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following packages were automatically installed and are no longer required:
  linux-headers-6.0.19-02540-g29b5aaf3e447 linux-image-6.0.19-02540-g29b5aaf3e447
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
ubuntu@pihole1:~$ sudo apt autoremove
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 2 to remove and 3 not upgraded.
After this operation, 187 MB disk space will be freed.
(Reading database ... 111323 files and directories currently installed.)
Removing linux-headers-6.0.19-02540-g29b5aaf3e447 (6.0.19-02540-g29b5aaf3e447-1) ...
Removing linux-image-6.0.19-02540-g29b5aaf3e447 (6.0.19-02540-g29b5aaf3e447-1) ...
update-initramfs: Deleting /boot/initrd.img-6.0.19-02540-g29b5aaf3e447
done
ubuntu@pihole1:~$ sudo apt clean
ubuntu@pihole1:~$ sudo reboot
See the second to last post. Le Potato eth port stopped working - #6 by librecomputer
Re-flash the bootloader to the latest. This affects older images with old bootloaders.
Thanks I’ll try that next
The shell scripts provided at
“GitHub - libre-computer-project/libretech-flash-tool”
rely on an https connection in bootloader.sh
“BOOTLOADER_URL=“Index of /ci/””
so the advice to run this
sudo ./lft.sh bl-flash aml-s905x-cc mmcblk1 force
on the potato itself is wrong.
BUT the advice is still valid - toss the SD card into another system. find the correct device with lsblk, make the script executable (chmod), then run
sudo ./lft.sh bl-flash aml-s905x-cc /your/path force
Worked great and the potato is live again. Thanks Libre!
In the GRUB stage, interrupt the bootloader and boot an older working kernel. Then run the command and then reboot. It should work.
That’s fair. I didn’t even think of that :frowning:
When I run this I get error bootloader server could not be reached.
I upgraded ubuntu and now it doesnt recognize my ethernet adapter which is why I am trying to run this
So I reimaged, flashed the bootloader, and then ran do-release-upgrade to upgrade to 24.02 and ethernet still doesnt work.
What kernel are you running? uname -r
I’m not sure if you figured it out by now or not, but after I upgraded my device got changed from eth0 → end0 so the netplan config was still pointing to eth0. I had to plug in a monitor and update the netplan config and it worked fine after that.
