Terribly sorry for the slow response. I was expecting an email when/if i got any replies. I did purchase another AML-S950X-CC and it does the same thing. I hope this is what you are looking for, it is awfully big.
Blockquote
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.0.16-02138-g398290e78036 (autobuild@deb.libre.computer) (gcc (Debian 8.3.0-6) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP PREEMPT_DYNAMIC Mon Jan 2 04:54:10 UTC 2023
[ 0.000000] Machine model: Libre Computer AML-S905X-CC
[ 0.000000] efi: EFI v2.90 by Das U-Boot
[ 0.000000] efi: ESRT=0x7ae51040 RTPROP=0x7ae53040 SMBIOS=0x7ae55000 RNG=0x5a222040 MEMRESERVE=0x5a221040
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] esrt: Reserving ESRT space from 0x000000007ae51040 to 0x000000007ae51078.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000006ac00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000000ffffff]
[ 0.000000] node 0: [mem 0x0000000001000000-0x0000000004ffffff]
[ 0.000000] node 0: [mem 0x0000000005000000-0x00000000072fffff]
[ 0.000000] node 0: [mem 0x0000000007300000-0x000000000fffffff]
[ 0.000000] node 0: [mem 0x0000000010000000-0x00000000101fffff]
[ 0.000000] node 0: [mem 0x0000000010200000-0x000000007ae52fff]
[ 0.000000] node 0: [mem 0x000000007ae53000-0x000000007ae53fff]
[ 0.000000] node 0: [mem 0x000000007ae54000-0x000000007ae54fff]
[ 0.000000] node 0: [mem 0x000000007ae55000-0x000000007ae57fff]
[ 0.000000] node 0: [mem 0x000000007ae58000-0x000000007ae58fff]
[ 0.000000] node 0: [mem 0x000000007ae59000-0x000000007ae5cfff]
[ 0.000000] node 0: [mem 0x000000007ae5d000-0x000000007de7ffff]
[ 0.000000] node 0: [mem 0x000000007de80000-0x000000007de8ffff]
[ 0.000000] node 0: [mem 0x000000007de90000-0x000000007fe5afff]
[ 0.000000] node 0: [mem 0x000000007fe5b000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
[ 0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.0.16-02138-g398290e78036 root=UUID=1cd42925-4305-4a79-bb10-f50d1fda10f8 ro noquiet
[ 0.000000] Unknown kernel command line parameters “noquiet BOOT_IMAGE=/boot/vmlinuz-6.0.16-02138-g398290e78036”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1694312K/2097152K available (14848K kernel code, 1928K rwdata, 6048K rodata, 3712K init, 505K bss, 140696K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Dynamic Preempt: full
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000665] Console: colour dummy device 80x25
[ 0.001185] printk: console [tty0] enabled
[ 0.001226] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.001250] pid_max: default: 32768 minimum: 301
[ 0.001318] LSM: Security Framework initializing
[ 0.001343] Yama: becoming mindful.
[ 0.001462] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001489] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002783] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002825] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002894] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003031] rcu: Hierarchical SRCU implementation.
[ 0.003045] rcu: Max phase no-delay instances is 1000.
[ 0.004314] Remapping and enabling EFI services.
[ 0.004672] smp: Bringing up secondary CPUs …
[ 0.005181] Detected VIPT I-cache on CPU1
[ 0.005310] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005894] Detected VIPT I-cache on CPU2
[ 0.006008] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006562] Detected VIPT I-cache on CPU3
[ 0.006678] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006766] smp: Brought up 1 node, 4 CPUs
[ 0.006837] SMP: Total of 4 processors activated.
[ 0.006849] CPU features: detected: 32-bit EL0 Support
[ 0.006859] CPU features: detected: 32-bit EL1 Support
[ 0.006872] CPU features: detected: CRC32 instructions
[ 0.007342] CPU: All CPU(s) started at EL2
[ 0.007378] alternatives: patching kernel code
[ 0.008739] devtmpfs: initialized
[ 0.014265] Registered cp15_barrier emulation handler
[ 0.014306] Registered setend emulation handler
[ 0.014486] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.014519] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.020654] pinctrl core: initialized pinctrl subsystem
[ 0.020929] regulator-dummy: no parameters, enabled
[ 0.021211] SMBIOS 3.0 present.
[ 0.021240] DMI: libre-computer aml-s905x-cc/aml-s905x-cc, BIOS 2022.07+ 07/01/2022
[ 0.021686] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.022734] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.023035] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.023201] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.023293] audit: initializing netlink subsys (disabled)
[ 0.023498] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[ 0.024771] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.024788] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.024810] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.025061] cpuidle: using governor menu
[ 0.025222] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.025337] ASID allocator initialised with 32768 entries
[ 0.038010] platform c883a000.hdmi-tx: Fixing up cyclic dependency with d0100000.vpu
[ 0.039326] platform cvbs-connector: Fixing up cyclic dependency with d0100000.vpu
[ 0.039759] platform hdmi-connector: Fixing up cyclic dependency with c883a000.hdmi-tx
[ 0.041851] KASLR enabled
[ 0.048659] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.048694] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.048710] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.048722] HugeTLB: 508 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.048736] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.048748] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.048761] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.048773] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.116652] raid6: neonx8 gen() 2145 MB/s
[ 0.184727] raid6: neonx4 gen() 2198 MB/s
[ 0.252796] raid6: neonx2 gen() 2086 MB/s
[ 0.320876] raid6: neonx1 gen() 1816 MB/s
[ 0.388938] raid6: int64x8 gen() 1492 MB/s
[ 0.457017] raid6: int64x4 gen() 1664 MB/s
[ 0.525075] raid6: int64x2 gen() 1418 MB/s
[ 0.593157] raid6: int64x1 gen() 1053 MB/s
[ 0.593169] raid6: using algorithm neonx4 gen() 2198 MB/s
[ 0.661208] raid6: … xor() 1584 MB/s, rmw enabled
[ 0.661221] raid6: using neon recovery algorithm
[ 0.661403] fbcon: Taking over console
[ 0.661755] VCC_3V3: 3300 mV, enabled
[ 0.661884] reg-fixed-voltage regulator-vcc_3v3: VCC_3V3 supplying 3300000uV
[ 0.662000] VDDIO_AO18: 1800 mV, enabled
[ 0.662085] reg-fixed-voltage regulator-vddio_ao18: VDDIO_AO18 supplying 1800000uV
[ 0.662181] VDDIO_BOOT: will resolve supply early: vin
[ 0.662188] reg-fixed-voltage regulator-vddio_boot: Looking up vin-supply from device tree
[ 0.662200] VDDIO_BOOT: supplied by VCC_3V3
[ 0.662208] VCC_3V3: could not add device link regulator.3: -ENOENT
[ 0.662266] VDDIO_BOOT: 1800 mV, enabled
[ 0.662344] reg-fixed-voltage regulator-vddio_boot: VDDIO_BOOT supplying 1800000uV
[ 0.662790] iommu: Default domain type: Passthrough
[ 0.663133] SCSI subsystem initialized
[ 0.663301] libata version 3.00 loaded.
[ 0.663499] usbcore: registered new interface driver usbfs
[ 0.663545] usbcore: registered new interface driver hub
[ 0.663581] usbcore: registered new device driver usb
[ 0.664014] pps_core: LinuxPPS API ver. 1 registered
[ 0.664029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.664054] PTP clock support registered
[ 0.664179] EDAC MC: Ver: 3.0.0
[ 0.664711] Registered efivars operations
[ 0.665093] FPGA manager framework
[ 0.665249] Advanced Linux Sound Architecture Driver Initialized.
[ 0.665820] NetLabel: Initializing
[ 0.665834] NetLabel: domain hash size = 128
[ 0.665844] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.665905] NetLabel: unlabeled traffic allowed by default
[ 0.666323] clocksource: Switched to clocksource arch_sys_counter
[ 0.666540] VFS: Disk quotas dquot_6.6.0
[ 0.666596] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.671964] NET: Registered PF_INET protocol family
[ 0.672148] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.673791] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.673887] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.673917] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.674037] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.674246] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.674502] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.674592] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.674646] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.674813] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.675246] RPC: Registered named UNIX socket transport module.
[ 0.675280] RPC: Registered udp transport module.
[ 0.675291] RPC: Registered tcp transport module.
[ 0.675301] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.675317] NET: Registered PF_XDP protocol family
[ 0.675338] PCI: CLS 0 bytes, default 64
[ 0.675534] Trying to unpack rootfs image as initramfs…
[ 0.683152] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.683748] kvm [1]: IPA Size Limit: 40 bits
[ 0.685036] kvm [1]: vgic interrupt IRQ9
[ 0.685156] kvm [1]: Hyp mode initialized successfully
[ 0.686686] Initialise system trusted keyrings
[ 0.686939] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.692703] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.693349] NFS: Registering the id_resolver key type
[ 0.693405] Key type id_resolver registered
[ 0.693418] Key type id_legacy registered
[ 0.693507] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.693524] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.693711] SGI XFS with ACLs, security attributes, no debug enabled
[ 0.695024] 9p: Installing v9fs 9p2000 file system support
[ 0.731652] xor: measuring software checksum speed
[ 0.735755] 8regs : 2442 MB/sec
[ 0.739728] 32regs : 2522 MB/sec
[ 0.743884] arm64_neon : 2405 MB/sec
[ 0.743916] xor: using function: 32regs (2522 MB/sec)
[ 0.743936] Key type asymmetric registered
[ 0.743947] Asymmetric key parser ‘x509’ registered
[ 1.374582] Freeing initrd memory: 16784K
[ 1.390929] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 1.391052] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.391172] io scheduler mq-deadline registered
[ 1.391187] io scheduler kyber registered
[ 1.391236] io scheduler bfq registered
[ 1.392008] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[ 1.407931] soc soc0: Amlogic Meson GXL (S905X) Revision 21:d (84:2) Detected
[ 1.412014] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.420031] loop: module loaded
[ 1.423634] tun: Universal TUN/TAP device driver, 1.6
[ 1.424665] VFIO - User Level meta-driver version: 0.3
[ 1.425919] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.425950] ehci-pci: EHCI PCI platform driver
[ 1.425993] ehci-platform: EHCI generic platform driver
[ 1.426120] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.426175] ohci-pci: OHCI PCI platform driver
[ 1.426221] ohci-platform: OHCI generic platform driver
[ 1.426692] usbcore: registered new interface driver usb-storage
[ 1.427589] i2c_dev: i2c /dev entries driver
[ 1.431512] sdhci: Secure Digital Host Controller Interface driver
[ 1.431546] sdhci: Copyright(c) Pierre Ossman
[ 1.431946] Synopsys Designware Multimedia Card Interface Driver
[ 1.432513] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.433461] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.434469] meson-sm: secure-monitor enabled
[ 1.435067] hid: raw HID events driver (C) Jiri Kosina
[ 1.435189] usbcore: registered new interface driver usbhid
[ 1.435204] usbhid: USB HID core driver
[ 1.435565] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[ 1.436793] meson-saradc c1108680.adc: Looking up vref-supply from device tree
[ 1.439355] NET: Registered PF_PACKET protocol family
[ 1.439696] 9pnet: Installing 9P2000 support
[ 1.439773] Key type dns_resolver registered
[ 1.440160] registered taskstats version 1
[ 1.440190] Loading compiled-in X.509 certificates
[ 1.442502] zswap: loaded using pool zstd/z3fold
[ 1.443673] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.459640] phy phy-d0078020.phy.0: Looking up phy-supply from device tree
[ 1.459663] phy phy-d0078020.phy.0: Looking up phy-supply property in node /soc/apb@d0000000/phy@78020 failed
[ 1.463273] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 22, base_baud = 1500000) is a meson_uart
[ 2.779288] printk: console [ttyAML0] enabled
[ 2.788470] meson-gx-mmc d0074000.mmc: Looking up vmmc-supply from device tree
[ 2.788709] meson-gx-mmc d0074000.mmc: Looking up vqmmc-supply from device tree
[ 2.788945] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[ 2.789800] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[ 2.810281] HDMI_5V: 5000 mV, enabled
[ 2.810461] reg-fixed-voltage regulator-hdmi-5v: HDMI_5V supplying 5000000uV
[ 2.810695] VCC_CARD: 1800 <–> 3300 mV at 3300 mV, enabled
[ 2.811009] phy phy-d0078000.phy.1: Looking up phy-supply from device tree
[ 2.811026] HDMI_5V: could not add device link phy-d0078000.phy.1: -ENOENT
[ 2.812422] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply from device tree
[ 2.812450] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply property in node /soc/usb@d0078080 failed
[ 2.812646] dwc3-meson-g12a d0078080.usb: USB2 ports: 2
[ 2.812684] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[ 2.826992] meson-gx-mmc d0074000.mmc: no support for card’s volts
[ 2.827540] mmc0: error -22 whilst initialising SDIO card
[ 3.329443] dwc2 c9100000.usb: Looking up vusb_d-supply from device tree
[ 3.329466] dwc2 c9100000.usb: Looking up vusb_d-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 3.329493] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[ 3.331161] dwc2 c9100000.usb: Looking up vusb_a-supply from device tree
[ 3.331170] dwc2 c9100000.usb: Looking up vusb_a-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 3.331188] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[ 3.338196] dwc2 c9100000.usb: Looking up vbus-supply from device tree
[ 3.338205] dwc2 c9100000.usb: Looking up vbus-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 3.339504] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[ 3.348395] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.350630] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.358203] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 3.364034] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
[ 3.373385] xhci-hcd xhci-hcd.0.auto: irq 25, io mem 0xc9000000
[ 3.379473] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 3.387408] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.394561] usb usb1: Product: xHCI Host Controller
[ 3.399387] usb usb1: Manufacturer: Linux 6.0.16-02138-g398290e78036 xhci-hcd
[ 3.406462] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.411735] hub 1-0:1.0: USB hub found
[ 3.415035] hub 1-0:1.0: 2 ports detected
[ 3.421306] meson-gx-mmc d0072000.mmc: Looking up vmmc-supply from device tree
[ 3.421454] meson-gx-mmc d0072000.mmc: Looking up vqmmc-supply from device tree
[ 3.421597] meson-gx-mmc d0072000.mmc: Got CD GPIO
[ 3.422127] of_cfs_init
[ 3.426203] of_cfs_init: OK
[ 3.429140] ALSA device list:
[ 3.431831] No soundcards found.
[ 3.453796] Freeing unused kernel memory: 3712K
[ 3.454077] Run /init as init process
[ 3.456459] with arguments:
[ 3.456465] /init
[ 3.456470] noquiet
[ 3.456474] with environment:
[ 3.456478] HOME=/
[ 3.456483] TERM=linux
[ 3.456487] BOOT_IMAGE=/boot/vmlinuz-6.0.16-02138-g398290e78036
[ 3.565200] mmc1: new ultra high speed SDR50 SDHC card at address 0001
[ 3.566904] mmcblk1: mmc1:0001 EB1QT 29.8 GiB
[ 3.572585] mmcblk1: p1 p2
[ 3.674394] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 3.823898] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 3.826478] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.833585] usb 1-1: Product: USB2.0 Hub
[ 3.850782] mmc0: Card stuck being busy! mmc_poll_for_busy
[ 3.891878] hub 1-1:1.0: USB hub found
[ 3.892280] hub 1-1:1.0: 4 ports detected
[ 3.901641] [drm] Initialized simpledrm 1.0.0 20200625 for 7fe5b000.framebuffer on minor 0
[ 3.919460] Console: switching to colour frame buffer device 90x36
[ 3.965187] simple-framebuffer 7fe5b000.framebuffer: [drm] fb0: simpledrmdrmfb frame buffer device
[ 3.991488] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 3.991512] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 3.999340] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[ 4.004315] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[ 4.011754] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[ 4.013721] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[ 4.013927] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[ 4.032275] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[ 4.033609] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[ 4.033654] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[ 4.040645] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[ 4.047297] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[ 4.069124] Console: switching to colour dummy device 80x25
[ 4.071093] lima d00c0000.gpu: bus rate = 166666667
[ 4.072155] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[ 4.073923] lima d00c0000.gpu: mod rate = 24000000
[ 4.081180] meson8b-dwmac c9410000.ethernet: DWMAC1000
[ 4.086043] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 4.090941] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[ 4.090953] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[ 4.090957] meson8b-dwmac c9410000.ethernet: COE Type 2
[ 4.090962] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[ 4.090966] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[ 4.091093] meson8b-dwmac c9410000.ethernet: Normal descriptors
[ 4.098409] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 4.105770] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[ 4.110960] lima d00c0000.gpu: error -ENODEV: opp_set_regulators: no regulator (mali) found
[ 4.117928] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.125987] [drm] Initialized lima 1.1.0 20191231 for d00c0000.gpu on minor 1
[ 4.157251] Trying to free nonexistent resource <000000007fe5b000-000000007ffeffff>
[ 4.167662] meson-dw-hdmi c883a000.hdmi-tx: Looking up hdmi-supply from device tree
[ 4.194417] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 4.199241] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 4.206832] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 4.216052] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 2
[ 4.226083] Console: switching to colour frame buffer device 90x36
[ 4.246352] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[ 4.256456] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 4.476977] usb 1-1.1: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 4.481303] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.488245] usb 1-1.1: Product: 802.11 n WLAN
[ 4.492171] usb 1-1.1: SerialNumber: 1.0
[ 4.677416] BTRFS: device label rootfs devid 1 transid 1745 /dev/mmcblk1p2 scanned by btrfs (230)
[ 4.799297] BTRFS info (device mmcblk1p2): using crc32c (crc32c-generic) checksum algorithm
[ 4.806863] BTRFS info (device mmcblk1p2): disk space caching is enabled
[ 4.824410] BTRFS info (device mmcblk1p2): enabling ssd optimizations
[ 4.827376] BTRFS info (device mmcblk1p2): start tree-log replay
[ 5.921518] systemd[1]: System time before build time, advancing clock.
[ 6.060238] NET: Registered PF_INET6 protocol family
[ 6.096792] Segment Routing with IPv6
[ 6.099160] RPL Segment Routing with IPv6
[ 6.101509] In-situ OAM (IOAM) with IPv6
[ 6.175987] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 6.210738] systemd[1]: Detected architecture arm64.
[ 6.221866] systemd[1]: Set hostname to .
[ 6.667281] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 6.785347] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.808152] systemd[1]: Created slice system-getty.slice.
[ 6.811944] systemd[1]: Created slice system-modprobe.slice.
[ 6.819701] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.827858] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 6.836352] systemd[1]: Created slice User and Session Slice.
[ 6.844258] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.857855] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.870796] systemd[1]: Reached target Slices.
[ 6.877215] systemd[1]: Reached target Swap.
[ 6.885621] systemd[1]: Listening on Syslog Socket.
[ 6.891338] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.899965] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.909030] systemd[1]: Listening on Journal Audit Socket.
[ 6.916350] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.924480] systemd[1]: Listening on Journal Socket.
[ 6.934532] systemd[1]: Listening on udev Control Socket.
[ 6.941658] systemd[1]: Listening on udev Kernel Socket.
[ 6.966659] systemd[1]: Mounting Huge Pages File System…
[ 6.976586] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.988727] systemd[1]: Mounting RPC Pipe File System…
[ 6.998269] systemd[1]: Mounting Kernel Debug File System…
[ 7.006096] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 7.006388] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 7.011114] systemd[1]: Starting Restore / save the current clock…
[ 7.061585] systemd[1]: Starting Set the console keyboard layout…
[ 7.073083] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 7.089542] systemd[1]: Starting Load Kernel Module configfs…
[ 7.100846] systemd[1]: Starting Load Kernel Module drm…
[ 7.110767] systemd[1]: Starting Load Kernel Module fuse…
[ 7.119362] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.119556] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.141439] systemd[1]: Starting Journal Service…
[ 7.151416] fuse: init (API version 7.36)
[ 7.157272] systemd[1]: Starting Load Kernel Modules…
[ 7.167044] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.179899] systemd[1]: Starting Coldplug All udev Devices…
[ 7.195069] systemd[1]: Mounted Huge Pages File System.
[ 7.202101] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.213884] systemd[1]: Mounted RPC Pipe File System.
[ 7.221447] systemd[1]: Mounted Kernel Debug File System.
[ 7.234893] systemd[1]: Finished Restore / save the current clock.
[ 7.248050] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 7.262425] systemd[1]: modprobe@configfs.service: Succeeded.
[ 7.263693] systemd[1]: Finished Load Kernel Module configfs.
[ 7.276840] systemd[1]: modprobe@drm.service: Succeeded.
[ 7.277948] systemd[1]: Finished Load Kernel Module drm.
[ 7.287902] systemd[1]: modprobe@fuse.service: Succeeded.
[ 7.289000] systemd[1]: Finished Load Kernel Module fuse.
[ 7.299922] systemd[1]: Finished Load Kernel Modules.
[ 7.304854] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.342743] systemd[1]: Mounting FUSE Control File System…
[ 7.351441] systemd[1]: Mounting Kernel Configuration File System…
[ 7.362851] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 7.373610] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 7.406966] systemd[1]: Starting Load/Save Random Seed…
[ 7.413329] systemd[1]: Starting Apply Kernel Variables…
[ 7.425688] systemd[1]: Starting Create System Users…
[ 7.438078] systemd[1]: Started Journal Service.
[ 7.501768] systemd-journald[320]: Received client request to flush runtime journal.
[ 7.618099] systemd-journald[320]: File /var/log/journal/3cbf3614064e4cca95f82571f80aa2c6/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 8.932483] mc: Linux media interface: v0.10
[ 8.951534] videodev: Linux video capture interface: v2.00
[ 8.962612] t9015-codec c8832000.audio-controller: Looking up AVDD-supply from device tree
[ 9.032328] Registered IR keymap rc-cec
[ 9.036592] rc rc0: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0
[ 9.036766] input: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0/input0
[ 9.043441] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.122920] Registered IR keymap rc-empty
[ 9.123043] rc rc1: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1
[ 9.123223] rc rc1: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[ 9.123363] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1/input1
[ 9.123787] meson-ir c8100580.ir: receiver initialized
[ 9.189724] simple-amplifier analog-amplifier: Looking up VCC-supply from device tree
[ 9.266399] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 9.266574] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 9.517441] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.587529] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 9.600346] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 9.755889] usb 1-1.1: reset high-speed USB device number 3 using xhci-hcd
[ 9.861872] mt7601u 1-1.1:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 9.871879] mt7601u 1-1.1:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146_
[ 10.352688] 8021q: 802.1Q VLAN Support v1.8
[ 10.429285] mt7601u 1-1.1:1.0: EEPROM ver:0c fae:00
[ 10.510697] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 10.520982] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS
[ 10.588198] meson8b-dwmac c9410000.ethernet eth0: PHY [mdio_mux-0.e40908ff:08] driver
