Raspberry PI compatible hardware
Hi
I have a sound card that is design for a RPI. It connects onto the RPI 40pin header.
If one was to run Raspian on the S905x could this board be compatible.
Sound card - IQaudio Codec Zero.
Thanks
Audio is routed via I2S which is not on the same pins for our boards due to pinmux limitations. The HAT will not work as is. You have to manually run a wire from the I2S capable pins to the I2S pins of the HAT.
