[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.19.14-03961-g1ed571629063 (autobuild@deb.libre.computer) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Wed Oct 5 17:14:31 UTC 2022
[ 0.000000] Machine model: Libre Computer ROC-RK3399-PC
[ 0.000000] efi: EFI v2.90 by Das U-Boot
[ 0.000000] efi: RTPROP=0xf0e40040 SMBIOS=0xf0e3c000 RNG=0xaff4c040 MEMRESERVE=0xaff4b040
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000200000-0x00000000f7ffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000200000-0x00000000aff4bfff]
[ 0.000000] node 0: [mem 0x00000000aff4c000-0x00000000aff4cfff]
[ 0.000000] node 0: [mem 0x00000000aff4d000-0x00000000f0e3bfff]
[ 0.000000] node 0: [mem 0x00000000f0e3c000-0x00000000f0e3cfff]
[ 0.000000] node 0: [mem 0x00000000f0e3d000-0x00000000f0e3ffff]
[ 0.000000] node 0: [mem 0x00000000f0e40000-0x00000000f0e40fff]
[ 0.000000] node 0: [mem 0x00000000f0e41000-0x00000000f0e41fff]
[ 0.000000] node 0: [mem 0x00000000f0e42000-0x00000000f0e43fff]
[ 0.000000] node 0: [mem 0x00000000f0e44000-0x00000000f0e44fff]
[ 0.000000] node 0: [mem 0x00000000f0e45000-0x00000000f0e48fff]
[ 0.000000] node 0: [mem 0x00000000f0e49000-0x00000000f3e6ffff]
[ 0.000000] node 0: [mem 0x00000000f3e70000-0x00000000f3e7ffff]
[ 0.000000] node 0: [mem 0x00000000f3e80000-0x00000000f5ffffff]
[ 0.000000] node 0: [mem 0x00000000f6000000-0x00000000f7fa3fff]
[ 0.000000] node 0: [mem 0x00000000f7fa4000-0x00000000f7ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.000000] cma: Reserved 384 MiB at 0x00000000d5000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s43432 r8192 d30296 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999432
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19.14-03961-g1ed571629063 root=UUID=7859446c-1bda-454c-aa80-b272caa94d99 ro noquiet splash vt.handoff=7
[ 0.000000] Unknown kernel command line parameters "noquiet splash BOOT_IMAGE=/boot/vmlinuz-5.19.14-03961-g1ed571629063", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 3503480K/4061184K available (12992K kernel code, 1736K rwdata, 5004K rodata, 3136K init, 468K bss, 164488K reserved, 393216K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @480000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000000440000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000000450000
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002140] Console: colour dummy device 80x25
[ 0.003256] printk: console [tty0] enabled
[ 0.003319] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.003363] pid_max: default: 32768 minimum: 301
[ 0.003481] LSM: Security Framework initializing
[ 0.003563] Yama: becoming mindful.
[ 0.003757] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003811] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.006162] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.006207] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.006333] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.006575] rcu: Hierarchical SRCU implementation.
[ 0.006598] rcu: Max phase no-delay instances is 1000.
[ 0.006988] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.007607] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.010036] Remapping and enabling EFI services.
[ 0.010594] smp: Bringing up secondary CPUs ...
[ 0.011324] Detected VIPT I-cache on CPU1
[ 0.011374] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.011398] GICv3: CPU1: using allocated LPI pending table @0x0000000000460000
[ 0.011458] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.012273] Detected VIPT I-cache on CPU2
[ 0.012312] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.012331] GICv3: CPU2: using allocated LPI pending table @0x0000000000470000
[ 0.012370] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.013090] Detected VIPT I-cache on CPU3
[ 0.013126] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.013145] GICv3: CPU3: using allocated LPI pending table @0x0000000000500000
[ 0.013182] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.013918] CPU features: detected: Spectre-v2
[ 0.013931] CPU features: detected: Spectre-v3a
[ 0.013940] CPU features: detected: Spectre-BHB
[ 0.013949] CPU features: detected: ARM erratum 1742098
[ 0.013957] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.013962] Detected PIPT I-cache on CPU4
[ 0.013996] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.014015] GICv3: CPU4: using allocated LPI pending table @0x0000000000510000
[ 0.014057] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.014830] Detected PIPT I-cache on CPU5
[ 0.014863] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.014880] GICv3: CPU5: using allocated LPI pending table @0x0000000000520000
[ 0.014913] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.015061] smp: Brought up 1 node, 6 CPUs
[ 0.015455] SMP: Total of 6 processors activated.
[ 0.015476] CPU features: detected: 32-bit EL0 Support
[ 0.015495] CPU features: detected: 32-bit EL1 Support
[ 0.015517] CPU features: detected: CRC32 instructions
[ 0.017005] CPU: All CPU(s) started at EL2
[ 0.017075] alternatives: patching kernel code
[ 0.019608] devtmpfs: initialized
[ 0.032905] Registered cp15_barrier emulation handler
[ 0.032944] Registered setend emulation handler
[ 0.032966] KASLR enabled
[ 0.033152] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.033190] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.041622] pinctrl core: initialized pinctrl subsystem
[ 0.042065]
[ 0.042079] *************************************************************
[ 0.042093] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.042105] ** **
[ 0.042144] ** IOMMU DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 0.042158] ** **
[ 0.042170] ** This means that this kernel is built to expose internal **
[ 0.042182] ** IOMMU data structures, which may compromise security on **
[ 0.042195] ** your system. **
[ 0.042207] ** **
[ 0.042219] ** If you see this message and you are not debugging the **
[ 0.042232] ** kernel, report this immediately to your vendor! **
[ 0.042244] ** **
[ 0.042256] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.042268] *************************************************************
[ 0.042491] SMBIOS 3.0 present.
[ 0.042523] DMI: libre-computer roc-rk3399-pc/roc-rk3399-pc, BIOS 2022.10-rc5+ 10/01/2022
[ 0.042988] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.044602] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.044856] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.045196] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.045281] audit: initializing netlink subsys (disabled)
[ 0.045483] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.046634] thermal_sys: Registered thermal governor 'step_wise'
[ 0.046644] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.047101] cpuidle: using governor menu
[ 0.047280] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.047479] ASID allocator initialised with 32768 entries
[ 0.047498] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.047515] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
[ 0.047530] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.047544] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
[ 0.070268] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc
[ 0.075290] platform ff940000.hdmi: Fixing up cyclic dependency with ff8f0000.vop
[ 0.075363] platform ff940000.hdmi: Fixing up cyclic dependency with ff900000.vop
[ 0.082973] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000
[ 0.083719] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000
[ 0.084232] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000
[ 0.084791] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000
[ 0.085350] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000
[ 0.103465] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.103496] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.103513] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.103530] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.105160] fbcon: Taking over console
[ 0.108052] iommu: Default domain type: Passthrough
[ 0.108362] SCSI subsystem initialized
[ 0.108750] usbcore: registered new interface driver usbfs
[ 0.108804] usbcore: registered new interface driver hub
[ 0.108852] usbcore: registered new device driver usb
[ 0.109343] pps_core: LinuxPPS API ver. 1 registered
[ 0.109359] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.109386] PTP clock support registered
[ 0.109620] EDAC MC: Ver: 3.0.0
[ 0.110411] Registered efivars operations
[ 0.110887] FPGA manager framework
[ 0.110992] Advanced Linux Sound Architecture Driver Initialized.
[ 0.111542] NetLabel: Initializing
[ 0.111559] NetLabel: domain hash size = 128
[ 0.111571] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.111637] NetLabel: unlabeled traffic allowed by default
[ 0.111958] clocksource: Switched to clocksource arch_sys_counter
[ 0.112178] VFS: Disk quotas dquot_6.6.0
[ 0.112235] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.120731] NET: Registered PF_INET protocol family
[ 0.120972] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.125538] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.125658] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.125690] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.126048] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.126725] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.126929] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.127079] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.127226] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.127498] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.127992] RPC: Registered named UNIX socket transport module.
[ 0.128015] RPC: Registered udp transport module.
[ 0.128028] RPC: Registered tcp transport module.
[ 0.128040] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.128057] NET: Registered PF_XDP protocol family
[ 0.128078] PCI: CLS 0 bytes, default 64
[ 0.128356] Trying to unpack rootfs image as initramfs...
[ 0.140949] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.141402] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.142257] kvm [1]: IPA Size Limit: 40 bits
[ 0.143399] kvm [1]: vgic-v2@fff20000
[ 0.143439] kvm [1]: GIC system register CPU interface enabled
[ 0.143672] kvm [1]: vgic interrupt IRQ18
[ 0.143893] kvm [1]: Hyp mode initialized successfully
[ 0.145547] Initialise system trusted keyrings
[ 0.145828] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.152861] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.153580] NFS: Registering the id_resolver key type
[ 0.153616] Key type id_resolver registered
[ 0.153630] Key type id_legacy registered
[ 0.153731] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.153749] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.153965] 9p: Installing v9fs 9p2000 file system support
[ 0.219232] Key type asymmetric registered
[ 0.219270] Asymmetric key parser 'x509' registered
[ 0.468130] Freeing initrd memory: 29556K
[ 0.490401] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.490500] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.490649] io scheduler mq-deadline registered
[ 0.490666] io scheduler kyber registered
[ 0.490719] io scheduler bfq registered
[ 0.508083] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.508122] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.509376] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.509403] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.518453] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.520508] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.521434] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.651929] printk: console [ttyS2] enabled
[ 0.657586] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.664270] loop: module loaded
[ 0.669338] spi-nor spi1.0: w25q128 (16384 Kbytes)
[ 0.684220] tun: Universal TUN/TAP device driver, 1.6
[ 0.685631] thunder_xcv, ver 1.0
[ 0.685965] thunder_bgx, ver 1.0
[ 0.686296] nicpf, ver 1.0
[ 0.687077] VFIO - User Level meta-driver version: 0.3
[ 0.692225] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.692825] ehci-pci: EHCI PCI platform driver
[ 0.693257] ehci-platform: EHCI generic platform driver
[ 0.693980] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.694551] ohci-pci: OHCI PCI platform driver
[ 0.694984] ohci-platform: OHCI generic platform driver
[ 0.696240] usbcore: registered new interface driver usb-storage
[ 0.700086] i2c_dev: i2c /dev entries driver
[ 0.707982] rk808 0-001b: chip id: 0x0
[ 0.712971] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.713555] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.726726] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.730086] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.736594] dw_wdt ff848000.watchdog: No valid TOPs array specified
[ 0.740564] cpu cpu0: EM: created perf domain
[ 0.742197] cpu cpu4: EM: created perf domain
[ 0.745517] sdhci: Secure Digital Host Controller Interface driver
[ 0.746188] sdhci: Copyright(c) Pierre Ossman
[ 0.746835] Synopsys Designware Multimedia Card Interface Driver
[ 0.747910] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.749334] mmc0: CQHCI version 5.10
[ 0.749677] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.750681] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.751274] hid: raw HID events driver (C) Jiri Kosina
[ 0.751762] usbcore: registered new interface driver usbhid
[ 0.752274] usbhid: USB HID core driver
[ 0.753926] NET: Registered PF_PACKET protocol family
[ 0.754907] 9pnet: Installing 9P2000 support
[ 0.755319] Key type dns_resolver registered
[ 0.756038] registered taskstats version 1
[ 0.756408] Loading compiled-in X.509 certificates
[ 0.761262] zswap: loaded using pool zstd/z3fold
[ 0.772180] mmc0: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA
[ 0.784595] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[ 0.785279] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[ 0.785563] of_cfs_init
[ 0.785886] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[ 0.786089] of_cfs_init: OK
[ 0.786607] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 0.787349] ALSA device list:
[ 0.787899] No soundcards found.
[ 0.788358] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[ 0.788378] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[ 0.802144] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.818157] Freeing unused kernel memory: 3136K
[ 0.832250] Run /init as init process
Loading, please wait...
Starting version 249.11-0ubuntu3.6
[ 1.103534] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[ 1.104171] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[ 1.104836] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[ 1.108056] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.108714] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.109226] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 1.109740] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.110338] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.110962] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.116520] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.117288] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 1.117957] rk_gmac-dwmac fe300000.ethernet: DWMAC1000
[ 1.118452] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[ 1.119150] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[ 1.119860] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[ 1.120435] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[ 1.121090] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[ 1.121853] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[ 1.122410] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[ 1.122938] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.138928] rk808-rtc rk808-rtc: registered as rtc0
[ 1.139014] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[ 1.140802] rk808-rtc rk808-rtc: setting system clock to 2022-10-10T20:45:06 UTC (1665434706)
[ 1.141840] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 1.143927] rockchip-vop ff900000.vop: Adding to iommu group 3
[ 1.145799] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 1.167330] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[ 1.171734] [drm] unsupported AFBC format[3231564e]
[ 1.175363] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[ 1.175646] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.177527] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator
[ 1.181205] panfrost ff9a0000.gpu: clock rate = 500000000
[ 1.182547] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[ 1.183202] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[ 1.183965] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[ 1.193913] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator
[ 1.196902] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[ 1.197311] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.201741] panfrost ff9a0000.gpu: [drm:panfrost_devfreq_init [panfrost]] Failed to register cooling device
[ 1.202738] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[ 1.203444] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400
[ 1.203934] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[ 1.205034] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[ 1.206191] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[ 1.208470] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[ 1.209239] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 1.210504] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 1.211516] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1
[ 1.228803] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.229747] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.276998] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 1.277619] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 1.278120] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[ 1.278740] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[ 1.279630] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[ 1.280390] pci 0000:00:00.0: supports D1
[ 1.280765] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.287234] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.288295] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 1.288966] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.289755] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[ 1.291017] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 1.292044] Registered IR keymap rc-cec
[ 1.292762] rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
[ 1.293415] input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input1
[ 1.306161] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[ 1.306780] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[ 1.307392] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa003fff 64bit]
[ 1.308284] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.308729] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
[ 1.309460] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.310164] pcieport 0000:00:00.0: PME: Signaling with IRQ 75
[ 1.310975] pcieport 0000:00:00.0: AER: enabled with IRQ 75
[ 1.312450] nvme nvme0: pci function 0000:01:00.0
[ 1.312931] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.449642] nvme nvme0: missing or invalid SUBNQN field.
[ 1.450436] nvme nvme0: Shutdown timeout set to 8 seconds
[ 1.466859] nvme nvme0: 6/0/0 default/read/poll queues
Begin: Loading essential drivers ... [ 62.428311] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP
[ 62.429053] Modules linked in: md_mod nvme nvme_core dw_hdmi_i2s_audio dw_hdmi_cec crct10dif_ce panfrost gpio_keys gpu_sched drm_shmem_helper phy_rockchip_pcie rtc_rk808 rockchipdrm analogix_dp dw_mipi_dsi ds
[ 62.432417] CPU: 3 PID: 148 Comm: kworker/3:1H Not tainted 5.19.14-03961-g1ed571629063 #1
[ 62.433183] Hardware name: libre-computer roc-rk3399-pc/roc-rk3399-pc, BIOS 2022.10-rc5+ 10/01/2022
[ 62.434017] Workqueue: kblockd blk_mq_timeout_work
[ 62.434497] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 62.435151] pc : nvme_timeout+0x50/0x390 [nvme]
[ 62.435615] lr : nvme_timeout+0x48/0x390 [nvme]
[ 62.436071] sp : ffff8000099e3be0
[ 62.436390] x29: ffff8000099e3be0 x28: ffff1b6745968048 x27: 0000000000000000
[ 62.437075] x26: ffff1b67f1f3d710 x25: 0000000000000001 x24: ffff1b67f257e800
[ 62.437758] x23: ffff1b67f2791b48 x22: 0000000000000001 x21: ffff1b67f2791a40
[ 62.438441] x20: ffff1b67f2548000 x19: ffff80000855201c x18: 00000000e4e013c2
[ 62.439124] x17: 000000000000001c x16: ffffc9082177d0c0 x15: 00000000ba8b212c
[ 62.439806] x14: ffffc908227da460 x13: ead5788dd6f7ff7d x12: e3f9902eec9c8f44
[ 62.440489] x11: 00000000f2be404c x10: 00000000b725ab16 x9 : 0000000000000000
[ 62.441171] x8 : ffff8000099e3c68 x7 : 0000000000000000 x6 : 0000000000000000
[ 62.441852] x5 : 00000000ffff1800 x4 : 0000000000000008 x3 : 0000000000000030
[ 62.442533] x2 : 0000000000000008 x1 : 0000000000000000 x0 : ffff8000099e3c28
[ 62.443216] Call trace:
[ 62.443456] nvme_timeout+0x50/0x390 [nvme]
[ 62.443882] blk_mq_check_expired+0x8c/0xd4
[ 62.444292] bt_iter+0xa8/0xd0
[ 62.444603] blk_mq_queue_tag_busy_iter+0x354/0x5b0
[ 62.445077] blk_mq_timeout_work+0x12c/0x1b0
[ 62.445492] process_one_work+0x1d0/0x320
[ 62.445884] worker_thread+0x14c/0x444
[ 62.446250] kthread+0x10c/0x110
[ 62.446577] ret_from_fork+0x10/0x20
[ 62.446942] Code: f9400314 9400069b f940d293 91007273 (b9400273)
[ 62.447514] ---[ end trace 0000000000000000 ]---
[ 0.000000] Memory: 3503472K/4061184K available (12992K kernel code, 1736K rwdata, 5004K rodata, 3136K init, 468K bss, 164496K reserved, 393216K cma-reserved)
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002114] Console: colour dummy device 80x25
[ 0.003226] printk: console [tty0] enabled
[ 0.003288] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.003331] pid_max: default: 32768 minimum: 301
[ 0.003449] LSM: Security Framework initializing
[ 0.003531] Yama: becoming mindful.
[ 0.003725] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.003780] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.006108] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.006152] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.006277] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.006516] rcu: Hierarchical SRCU implementation.
[ 0.006540] rcu: Max phase no-delay instances is 1000.
[ 0.006935] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.007488] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.009959] Remapping and enabling EFI services.
[ 0.010509] smp: Bringing up secondary CPUs ...
[ 0.011234] Detected VIPT I-cache on CPU1
[ 0.011284] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.011306] GICv3: CPU1: using allocated LPI pending table @0x0000000000460000
[ 0.011365] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.012238] Detected VIPT I-cache on CPU2
[ 0.012277] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.012296] GICv3: CPU2: using allocated LPI pending table @0x0000000000470000
[ 0.012335] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.013050] Detected VIPT I-cache on CPU3
[ 0.013086] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.013104] GICv3: CPU3: using allocated LPI pending table @0x0000000000500000
[ 0.013140] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.013876] CPU features: detected: Spectre-v2
[ 0.013889] CPU features: detected: Spectre-v3a
[ 0.013898] CPU features: detected: Spectre-BHB
[ 0.013906] CPU features: detected: ARM erratum 1742098
[ 0.013914] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.013919] Detected PIPT I-cache on CPU4
[ 0.013954] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.013973] GICv3: CPU4: using allocated LPI pending table @0x0000000000510000
[ 0.014015] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.014784] Detected PIPT I-cache on CPU5
[ 0.014817] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.014834] GICv3: CPU5: using allocated LPI pending table @0x0000000000520000
[ 0.014867] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.015014] smp: Brought up 1 node, 6 CPUs
[ 0.015406] SMP: Total of 6 processors activated.
[ 0.015427] CPU features: detected: 32-bit EL0 Support
[ 0.015446] CPU features: detected: 32-bit EL1 Support
[ 0.015468] CPU features: detected: CRC32 instructions
[ 0.016931] CPU: All CPU(s) started at EL2
[ 0.017000] alternatives: patching kernel code
[ 0.019525] devtmpfs: initialized
[ 0.032824] Registered cp15_barrier emulation handler
[ 0.032863] Registered setend emulation handler
[ 0.032885] KASLR enabled
[ 0.033073] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.033110] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.040587] pinctrl core: initialized pinctrl subsystem
[ 0.041042]
[ 0.041056] *************************************************************
[ 0.041069] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.041082] ** **
[ 0.041095] ** IOMMU DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 0.041107] ** **
[ 0.041119] ** This means that this kernel is built to expose internal **
[ 0.041132] ** IOMMU data structures, which may compromise security on **
[ 0.041144] ** your system. **
[ 0.041156] ** **
[ 0.041168] ** If you see this message and you are not debugging the **
[ 0.041180] ** kernel, report this immediately to your vendor! **
[ 0.041192] ** **
[ 0.041205] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.041217] *************************************************************
[ 0.041438] SMBIOS 3.0 present.
[ 0.041469] DMI: libre-computer roc-rk3399-pc/roc-rk3399-pc, BIOS 2022.10-rc5+ 10/01/2022
[ 0.041937] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.043580] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.043837] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.044176] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.044261] audit: initializing netlink subsys (disabled)
[ 0.044461] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.045591] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045600] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.046055] cpuidle: using governor menu
[ 0.046260] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.046458] ASID allocator initialised with 32768 entries
[ 0.046478] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.046495] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
[ 0.046511] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.046525] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
[ 0.069264] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc
[ 0.074296] platform ff940000.hdmi: Fixing up cyclic dependency with ff8f0000.vop
[ 0.074368] platform ff940000.hdmi: Fixing up cyclic dependency with ff900000.vop
[ 0.081954] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000
[ 0.082695] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000
[ 0.083227] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000
[ 0.083787] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000
[ 0.084347] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000
[ 0.102473] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.102503] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.102520] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.102536] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.104203] fbcon: Taking over console
[ 0.107030] iommu: Default domain type: Passthrough
[ 0.107350] SCSI subsystem initialized
[ 0.107753] usbcore: registered new interface driver usbfs
[ 0.107805] usbcore: registered new interface driver hub
[ 0.107856] usbcore: registered new device driver usb
[ 0.108354] pps_core: LinuxPPS API ver. 1 registered
[ 0.108370] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.108397] PTP clock support registered
[ 0.108629] EDAC MC: Ver: 3.0.0
[ 0.109429] Registered efivars operations
[ 0.109928] FPGA manager framework
[ 0.110042] Advanced Linux Sound Architecture Driver Initialized.
[ 0.110615] NetLabel: Initializing
[ 0.110632] NetLabel: domain hash size = 128
[ 0.110645] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.110712] NetLabel: unlabeled traffic allowed by default
[ 0.111025] clocksource: Switched to clocksource arch_sys_counter
[ 0.111245] VFS: Disk quotas dquot_6.6.0
[ 0.111306] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.119660] NET: Registered PF_INET protocol family
[ 0.119886] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.124419] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.124537] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.124568] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.124925] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.125603] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.125814] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.125931] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.126081] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.126353] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.126812] RPC: Registered named UNIX socket transport module.
[ 0.126834] RPC: Registered udp transport module.
[ 0.126847] RPC: Registered tcp transport module.
[ 0.126860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.126876] NET: Registered PF_XDP protocol family
[ 0.126896] PCI: CLS 0 bytes, default 64
[ 0.127202] Trying to unpack rootfs image as initramfs...
[ 0.140015] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.140461] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.141318] kvm [1]: IPA Size Limit: 40 bits
[ 0.142457] kvm [1]: vgic-v2@fff20000
[ 0.142498] kvm [1]: GIC system register CPU interface enabled
[ 0.142728] kvm [1]: vgic interrupt IRQ18
[ 0.142942] kvm [1]: Hyp mode initialized successfully
[ 0.144555] Initialise system trusted keyrings
[ 0.144849] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.151800] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.152506] NFS: Registering the id_resolver key type
[ 0.152543] Key type id_resolver registered
[ 0.152557] Key type id_legacy registered
[ 0.152640] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.152657] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.152863] 9p: Installing v9fs 9p2000 file system support
[ 0.218140] Key type asymmetric registered
[ 0.218175] Asymmetric key parser 'x509' registered
[ 0.458510] Freeing initrd memory: 29556K
[ 0.480559] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.480652] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.480806] io scheduler mq-deadline registered
[ 0.480823] io scheduler kyber registered
[ 0.480874] io scheduler bfq registered
[ 0.498079] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.498115] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.499388] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.499416] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.508437] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.510470] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.511426] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.641880] printk: console [ttyS2] enabled
[ 0.647481] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.654114] loop: module loaded
[ 0.659221] spi-nor spi1.0: w25q128 (16384 Kbytes)
[ 0.673874] tun: Universal TUN/TAP device driver, 1.6
[ 0.675320] thunder_xcv, ver 1.0
[ 0.675660] thunder_bgx, ver 1.0
[ 0.675990] nicpf, ver 1.0
[ 0.676770] VFIO - User Level meta-driver version: 0.3
[ 0.681868] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.682469] ehci-pci: EHCI PCI platform driver
[ 0.682900] ehci-platform: EHCI generic platform driver
[ 0.683655] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.684227] ohci-pci: OHCI PCI platform driver
[ 0.684666] ohci-platform: OHCI generic platform driver
[ 0.685901] usbcore: registered new interface driver usb-storage
[ 0.689709] i2c_dev: i2c /dev entries driver
[ 0.694496] dc_12v: Bringing 5000000uV into 12000000-12000000uV
[ 0.699848] rk808 0-001b: chip id: 0x0
[ 0.705200] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.705783] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.718908] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.722497] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.729224] dw_wdt ff848000.watchdog: No valid TOPs array specified
[ 0.733203] cpu cpu0: EM: created perf domain
[ 0.734975] cpu cpu4: EM: created perf domain
[ 0.738093] sdhci: Secure Digital Host Controller Interface driver
[ 0.738660] sdhci: Copyright(c) Pierre Ossman
[ 0.740146] Synopsys Designware Multimedia Card Interface Driver
[ 0.741772] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.743184] mmc0: CQHCI version 5.10
[ 0.743552] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.744691] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.745284] hid: raw HID events driver (C) Jiri Kosina
[ 0.745773] usbcore: registered new interface driver usbhid
[ 0.746263] usbhid: USB HID core driver
[ 0.747875] NET: Registered PF_PACKET protocol family
[ 0.748613] 9pnet: Installing 9P2000 support
[ 0.749018] Key type dns_resolver registered
[ 0.749614] registered taskstats version 1
[ 0.749983] Loading compiled-in X.509 certificates
[ 0.753945] zswap: loaded using pool zstd/z3fold
[ 0.767266] mmc0: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA
[ 0.783629] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[ 0.784302] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[ 0.784747] of_cfs_init
[ 0.784887] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[ 0.785112] of_cfs_init: OK
[ 0.785630] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 0.786318] ALSA device list:
[ 0.786923] No soundcards found.
[ 0.787375] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[ 0.787407] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[ 0.802175] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.818178] Freeing unused kernel memory: 3136K
[ 0.818693] Run /init as init process
[ 1.103104] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[ 1.103723] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[ 1.104412] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[ 1.105170] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.105812] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.106326] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[ 1.106844] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.108882] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.109558] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.115131] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.120103] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 1.120777] rk_gmac-dwmac fe300000.ethernet: DWMAC1000
[ 1.123864] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[ 1.124568] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[ 1.125240] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[ 1.125711] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[ 1.126337] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[ 1.128235] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[ 1.128795] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[ 1.129326] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.139406] rk808-rtc rk808-rtc: registered as rtc0
[ 1.147156] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:31 UTC (1358499031)
[ 1.153714] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[ 1.153960] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[ 1.154930] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[ 1.155891] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[ 1.157366] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[ 1.164249] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 1.167250] rockchip-vop ff900000.vop: Adding to iommu group 3
[ 1.168751] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 1.170003] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.174477] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[ 1.175446] [drm] unsupported AFBC format[3231564e]
[ 1.177932] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[ 1.178855] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator
[ 1.184021] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator
[ 1.184667] panfrost ff9a0000.gpu: clock rate = 500000000
[ 1.184885] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.187104] panfrost ff9a0000.gpu: [drm:panfrost_devfreq_init [panfrost]] Failed to register cooling device
[ 1.188097] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[ 1.188797] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400
[ 1.189527] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[ 1.189979] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[ 1.190560] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
1;-1fdone.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... [ 4.223008] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
Scanning for Btrfs filesystems
[ 4.230281] SError Interrupt on CPU1, code 0x00000000bf000002 -- SError
[ 4.230293] CPU: 1 PID: 303 Comm: btrfs Not tainted 5.19.14-03961-g1ed571629063 #1
[ 4.230299] Hardware name: libre-computer roc-rk3399-pc/roc-rk3399-pc, BIOS 2022.10-rc5+ 10/01/2022
[ 4.230303] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 4.230309] pc : _raw_spin_unlock+0x10/0x4c
[ 4.230324] lr : nvme_queue_rqs+0x194/0x250 [nvme]
[ 4.230339] sp : ffff80000884b870
[ 4.230341] x29: ffff80000884b870 x28: ffff1b34b2458000 x27: 0000000000000000
[ 4.230350] x26: ffff1b34b268b000 x25: 0000000000000000 x24: ffff1b34b2683988
[ 4.230357] x23: 0000000000000000 x22: ffff80000884b9e0 x21: ffff1b34b2683980
[ 4.230364] x20: 00000000ffffffff x19: 0000000000000000 x18: 0000000000000000
[ 4.230371] x17: 0000000000000000 x16: ffffb4cf7f685924 x15: 0000000000000001
[ 4.230377] x14: 0000000000000002 x13: 00000000000e7514 x12: 0000000000000000
[ 4.230384] x11: 0000000000000000 x10: 000000000000fff1 x9 : ffff1b34b2689088
[ 4.230390] x8 : 0000000000008000 x7 : 00000000fffedf29 x6 : ffff800008606000
[ 4.230397] x5 : 0000000000000000 x4 : 0000000780000007 x3 : 0000000000000000
[ 4.230404] x2 : 0000000000000000 x1 : ffff1b34b2458000 x0 : 0000000100000001
[ 4.230413] Kernel panic - not syncing: Asynchronous SError Interrupt
[ 4.230417] CPU: 1 PID: 303 Comm: btrfs Not tainted 5.19.14-03961-g1ed571629063 #1
[ 4.230422] Hardware name: libre-computer roc-rk3399-pc/roc-rk3399-pc, BIOS 2022.10-rc5+ 10/01/2022
[ 4.230425] Call trace:
[ 4.230427] dump_backtrace.part.0+0xc8/0xd4
[ 4.230437] show_stack+0x18/0x5c
[ 4.230444] dump_stack_lvl+0x68/0x84
[ 4.230450] dump_stack+0x18/0x34
[ 4.230454] panic+0x16c/0x32c
[ 4.230461] add_taint+0x0/0xb0
[ 4.230467] arm64_serror_panic+0x6c/0x7c
[ 4.230472] do_serror+0x58/0x5c
[ 4.230476] el1h_64_error_handler+0x30/0x50
[ 4.230481] el1h_64_error+0x64/0x68
[ 4.230486] _raw_spin_unlock+0x10/0x4c
[ 4.230493] blk_mq_flush_plug_list+0x16c/0x23c
[ 4.230501] __blk_flush_plug+0xf0/0x140
[ 4.230509] blk_finish_plug+0x38/0x260
[ 4.230514] read_pages+0x1b8/0x330
[ 4.230519] page_cache_ra_unbounded+0x154/0x1b4
[ 4.230524] force_page_cache_ra+0xcc/0x100
[ 4.230528] page_cache_sync_ra+0x44/0xa4
[ 4.230532] filemap_get_pages+0xac/0x650
[ 4.230539] filemap_read+0xb0/0x3b0
[ 4.230544] blkdev_read_iter+0xc4/0x200
[ 4.230549] new_sync_read+0xd4/0x150
[ 4.230556] vfs_read+0x190/0x1e0
[ 4.230561] ksys_read+0x68/0xfc
[ 4.230566] __arm64_sys_read+0x1c/0x30
[ 4.230572] invoke_syscall+0x48/0x114
[ 4.230579] el0_svc_common.constprop.0+0x44/0xfc
[ 4.230585] do_el0_svc+0x30/0xc0
[ 4.230590] el0_svc+0x34/0xb0
[ 4.230594] el0t_64_sync_handler+0xbc/0x140
[ 4.230599] el0t_64_sync+0x18c/0x190
[ 4.230606] SMP: stopping secondary CPUs
[ 4.230680] Kernel Offset: 0x34cf769e0000 from 0xffff800008000000
[ 4.230683] PHYS_OFFSET: 0xffffe4cc00000000
[ 4.230685] CPU features: 0x2000,04125811,00001086
[ 4.230689] Memory Limit: none
[ 4.255128] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
RK3399 only supports PCIe 1, trying PCIe 2 is stretching it and leads to instability.
