I should be able to power the Renegade from J1.2 and or J1.4, correct? Is there a catch? Such as bypassing the reverse input protection diode.
You can power it directly via 5V. Just check the reverse path from those pins to the PMIC and the implications of device control when you power VCC_SYS directly.
