ROC-RK3328-CC Active Cooling
As I start to pile on running applications, my board is getting warmer. Even headless it runs about 45c rn with cheap pads and aluminum fins. Will this rpi3b/4b active cooling solution work for these boards? I printed a pi3b case that fit when the pi4 case did not. Just looking for experience/confirmation.
Probably not because the SoC position is different. The heatsink and fan pictured is overkill. Just get the custom heatsink and the active cooling media center case. The board will not throttle with those two.
I just like the rgbpuke… Gonna put it in a desktop computer-looking case, thought it might be fun. But thanks for the note on soc placement.
