Can anyone assist locating the source code to convert RPi GPIO to GPIOD?
I’m not sure what you mean by “convert” in this case, but here is a link to my libgpiod example on the Python Bindings thread for the aml-s905x-cc. If you’re using a board other than le Potato you’ll just need to look up the chip and line numbers for your board.
As far as I know, RPi.GPIO hasn’t been ported to these boards, and probably wont ever be. First paragraph from the above mentioned thread’s OP:
There’s no source code to covert RPi.GPIO to use gpiod. We have text based GPIO maps that can be loaded into Python. We may create a library based on that in the future.
Thanks for the responses. Anytime I enter “import gpiod” I get command not found after following the tutorials.
How are you trying to run it? Sounds like you’re trying to run a script without making it executable first, or skipping the “./” .
