gpioget 1 98
always returns 0. Is this normal for that pin ? it’s the pin “GPIOCLK_0”
pins with gpio # 87-90 work as expected (only when button is pressed, value is 0 otherwise 1). I am a bit cramped for wire space so was hoping to use 1 98
gpioget 1 98
Did you bias pull up?
how do I check this ?
Use gpioget --help
Fixed ! thanks !
I just did gpioget -B disable 1 98 and then it works as others
is there a standard way to make the bias setting persist ? the command gpioget -B disable 1 98 gets reset on restart
You need to write a device tree overlay that targets that pin so the pinctrl driver will set the proper bias when probing the controller.
