[SOLVED] Bootstrap Debian into the eMMC but GRUB not found
Hi @librecomputer
I followed your advice and tried to bootstrap directly Debian into the eMMC module, but at the end of the process GRUB is still not found, clearly I am missing some key steps but do not which ones.
CHROOT: create and update grub
echo "GRUB_ENABLE_CRYPTODISK=y" >> /etc/default/grub
grub-install /dev/mmcblk0
[OK]
update-grub
[OK]
Exit CHROOT
Reflash bootloader
cd libre[tab]
./lfth.sh bl-flash roc-rk3328-cc mmcblk0 verify
[OK]
Reboot (removing the SD Card)
Did not work :frowning:
Unfortunately after the reboot it does’t boot.
If I connect the board through HDMI → VGA I can display the buffer, on this other monitor HDMI → HDMI I can’t but the green light is not blinking.
I don’t know where I am mistaken, perhaps this can help anyone to spot it out. I can provide some logs just tell me which I should grab from the eMMC, thanks! :folded_hands:
GRUB needs to be installed in the extra-removables path.
Thank you very much :pray:
I apology for my ignorance, what are these extra-removables path?
Thanks! :pray:
Please use Google if you are not clear.
It worked, thanks… :+1:
This is the much better, cleaner, faster way.
