Sweet Potato / Firmware Update: Wrong image format for "source" command?
Hi all,
everyone also run in this firmware update error? Is this a normal behavior?
�@GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:0;RCY:0;USB:0;0.0;CHK:0;
TE: 1710904
        z
BL2 Built : 15:21:18, Aug 28 2019. gxl g1bf2b53 - luan.yuan@droid15
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 4
CPU clk: 1200MHz
BL2 USB
DDR enable rdbi
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0 @ 1080MHz
bist_test rank: 0 16 01 2b 25 16 35 11 00 23 29 1b 37 12 00 25 27
Rank0: 2048MB(auto)-2T-18
Load fip header from USB, src: 0x0000c000, des: 0x01400000, size: 0
New fip structure!
Load bl30 from USB, src: 0x00010000, des: 0x013c0000, size: 0x00000
Load bl31 from USB, src: 0x00020000, des: 0x05100000, size: 0x00010
Load bl33 from USB, src: 0x0003c000, des: 0x01000000, size: 0x000b0
NOTICE:  BL31: v1.3(release):c3714b49be
NOTICE:  BL31: Built : 09:23:36, Jun 20 2023. gxl bl-3.5.0 gc3714bh
NOTICE:  BL3-1: GXL normal boot!
NOTICE:  BL31: BL33 decompress pass
mpu_config_enable:system pre init ok
OPS=0x84
dmc sec lock
[Image: gxl_v1.1.3509-d977ed20a4 2023-06-20 09:43:46 jenkins@walle]
21 0d 84 00 5e e2 9c f0 3e 39 f8 82 55 dc ad cd
[8.035232 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
<debug_uart>
[BL31]: tee size: 0
[BL31]: tee size: 0
Net:   eth0: ethernet@c9410000
(ROM USB boot)
## Executing script at 08000000
SF: Detected gd25lq128 with page size 256 Bytes, erase size 64 KiBB
dwc3_meson_gxl_get_phys: usb2 ports: 2
dwc3_meson_gxl_force_mode: switching to Device Mode
0 bytes written, 65536 bytes skipped in 0.11s, speed 6100805 B/s
0 bytes written, 65536 bytes skipped in 0.10s, speed 6710886 B/s
0 bytes written, 65536 bytes skipped in 0.10s, speed 6100805 B/s
#DOWNLOAD ... OK
Ctrl+C to exit ...
/usr/bin/dfu-util
--2026-03-30 15:40:02--  https://boot.libre.computer/ci/aml-s905x-cc-v2-spi
Auflösen des Hostnamens boot.libre.computer… 2600:3c00::f03c:93ff:fea1:358c, 192.53.162.101
Verbindungsaufbau zu boot.libre.computer|2600:3c00::f03c:93ff:fea1:358c|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Länge: 1114112 (1,1M) [application/octet-stream]
Wird in »/tmp/tmp.VeLJoGaPwA« gespeichert.
/tmp/tmp.VeLJoGaPwA               100%[=============================================================>]   1,06M   959KB/s    in 1,1s
2026-03-30 15:40:04 (959 KB/s) - »/tmp/tmp.VeLJoGaPwA« gespeichert [1114112/1114112]
Please plug in the board's OTG port with the USB/BOOT button held down. Waiting for 60s...
Waiting for device enumeration...24s
+ '[' gxl = gxl ']'
+ ./boot.py aml-s905x-cc-v2
/usr/src/pyamlboot/./boot.py:9: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
  import pkg_resources
Using GX Family boot parameters
ROM: 2.4 Stage: 0.0
Writing /usr/src/pyamlboot/files/aml-s905x-cc-v2/u-boot.bin.usb.bl2 at 0xd9000000...
[DONE]
Writing /usr/src/pyamlboot/files/usbbl2runpara_ddrinit.bin at 0xd900c000...
[DONE]
Running at 0xd9000000...
[DONE]
Waiting...
[DONE]
ROM: 2.2 Stage: 0.8
Running at 0xd900c000...
[DONE]
Waiting...
[DONE]
[DONE]
Writing /usr/src/pyamlboot/files/usbbl2runpara_runfipimg.bin at 0xd900c000...
[DONE]
Writing /usr/src/pyamlboot/files/aml-s905x-cc-v2/u-boot.bin.usb.tpl at 0x200c000...
[DONE]
[DONE]
+ '[' '!' -z firmware-update ']'
+ '[' firmware-update = firmware-update ']'
+ dfu-util --device 1b8e:fada -a 0 -w -D /tmp/tmp.VeLJoGaPwA
dfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
Waiting for device, exit with ctrl-C
Opening DFU capable USB device...
Device ID 1b8e:fada
Device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0110
Device returned transfer size 4096
Copying data from PC to DFU device
Download	[=========================] 100%      1114112 bytes
Download done.
DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
Done!
+ '[' firmware-update = firmware-flash ']'
+ '[' 0 -eq 0 ']'
+ break
+ rm /tmp/tmp.VeLJoGaPwA
That’s an inconsequential error.
