Hi, i’ve connected my i2c bus to a number of devices. i’ve run the following commands in an attempt to communicate with them.
$ ldto enable i2c-ao
$ i2cdetect -l
i2c-1 i2c Meson I2C adapter I2C adapter
i2c-0 i2c DesignWare HDMI I2C adapter
$ i2cdetect 1
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-1.
I will probe address range 0x08-0x77.
Continue? [Y/n]
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 08 -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
$ echo realtime_clock 0x68 > /sys/bus/i2c/devices/i2c-1/new-device
However, i’m stuck on how to communicate with the device either through sysfs or some other api? Is there a C api or some other sysfs file im supposed to write to?
Thanks
