Hello, I am attempting to update Raspbian after first boot on ALL-H3-CC board. I flashed the latest arm64 image from the distro server.
After the first boot and initial setup, I ran sudo raspi-config and configured the wifi etc, then rebooted.
After this, I ran sudo apt update -y then sudo apt upgrade -y
Upon running apt upgrade, the output yields the following warnings at the end of the upgrade:
Processing triggers for initramfs-tools (0.140) ...
update-initramfs: Generating /boot/initrd.img-6.1.46-08797-g9c18484153bc
W: Possible missing firmware /lib/firmware/bnx2/bnx2-rv2p-09ax-6.0.17.fw for built-in driver bnx2
W: Possible missing firmware /lib/firmware/bnx2/bnx2-rv2p-09-6.0.17.fw for built-in driver bnx2
W: Possible missing firmware /lib/firmware/bnx2/bnx2-mips-09-6.2.1b.fw for built-in driver bnx2
W: Possible missing firmware /lib/firmware/bnx2/bnx2-rv2p-06-6.0.15.fw for built-in driver bnx2
W: Possible missing firmware /lib/firmware/bnx2/bnx2-mips-06-6.2.3.fw for built-in driver bnx2
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e2-7.13.15.0.fw for built-in driver bnx2x
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e1h-7.13.15.0.fw for built-in driver bnx2x
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e1-7.13.15.0.fw for built-in driver bnx2x
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e2-7.13.21.0.fw for built-in driver bnx2x
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e1h-7.13.21.0.fw for built-in driver bnx2x
W: Possible missing firmware /lib/firmware/bnx2x/bnx2x-e1-7.13.21.0.fw for built-in driver bnx2x
Is this an issue to be concerned, or just ignore these errors?
BNX2X appears to be a driver for QLogic 578xx 10gig ethernet adapters? So if this adapter isn’t present on the board not sure why these are being loaded…
Thank you for any info.
