Is there a plan to upstream the fix when probing the ethernet PHY when it’s behind the mdio-mux?
It would be nice to use the newer upstream kernel versions.
The upstream hack was simply to have the PHY as a builtin and avoid it as a module. As this touch the stmmac code, a larger revision is likely needed.
