Hi,
Need help with Touchscreen configuration for waveshare 4" HDMI touch screen.
I tried everything mentioned in hub, but still touch is not working.
Thank you,
Shailesh
Hi,
Thank you,
Shailesh
Does it display anything or does touch not work?
Display is working perfectly, only issue is with touch screen.
I see these messages.
[ 630.720042] ads7846 spi0.1: Looking up vcc-supply from device tree
[ 630.720093] ads7846 spi0.1: Looking up vcc-supply property in node /soc/bus@c1100000/spi@8d80/touchscreen@1 failed
[ 630.720172] ads7846 spi0.1 : supply vcc not found, using dummy regulator
[ 630.732973] ads7846 spi0.1: touchscreen, irq 51
[ 630.733745] input: ADS7846 Touchscreen as /devices/platform/soc/c1100000.bus/c1108d80.spi/spi_master/spi0/spi0.1/input/input7
What board are you running? What did you run to enable the display? Did you follow this?
Yes I follow the instructions you mentioned and after that only I am seeing those log message I mentioned in earlier post. and I am using below mentioned board
Thank you,
Shailesh singh
Run evtest and then touch the screen. Does it show anything?
Run watch -n 1 cat /proc/interrupts and see if the interrupt pin is incrementing when you touch the screen.
It could also be that the SPI frequency is too high and needs to be lowered in the overlay. Change the max-frequency of the overlay to match Waveshare’s 50KHz setting. Compile and load it.
