I am using Devuan with your kernel (and APT settings) and so far everything is going great!
uname -a
Linux RK3328 6.1.54-10001-gd517e36a604d #1 SMP PREEMPT_DYNAMIC Fri Sep 22 22:11:56 EDT 2023 aarch64 GNU/Linux
I am using a stateless Xorg config file but I wonder if you can recommend any Xorg settings to squeeze more performance from this board.
For what I can see, it looks like you compiled the GPU driver as module into the kernel:
dmesg | grep gpu
[sudo] password for freezr:
[ 46.739362] lima ff300000.gpu: Looking up mali-supply from device tree
[ 46.739955] lima ff300000.gpu: gp - mali450 version major 0 minor 0
[ 46.740048] lima ff300000.gpu: pp0 - mali450 version major 0 minor 0
[ 46.740124] lima ff300000.gpu: pp1 - mali450 version major 0 minor 0
[ 46.740178] lima ff300000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[ 46.740201] lima ff300000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[ 46.746914] lima ff300000.gpu: bus rate = 163840000
[ 46.746952] lima ff300000.gpu: mod rate = 163840000
[ 46.747028] lima ff300000.gpu: Looking up mali-supply from device tree
[ 46.747108] vdd_logic: could not add device link ff300000.gpu: -EEXIST
[ 46.751147] [drm] Initialized lima 1.1.0 20191231 for ff300000.gpu on minor 1
freezr ) sudo dmesg | grep -i gpu
Thanks in advance! ![]()
