Model: Libre computers - Le potato
Display - 32 inch 60hz LG monitor hooked up with HDMI
EDID: i don’t know what this is fully but it seems to say the following - Linux raspberrypi 6.0.12-00858-gb98721ea4575 #1smp preempt_dynamic
The programs included with the debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*copyright
Debian GNU/Linux comes with absolutely no warranty, to the extent permitted by applicable law.
-What should i do now?
Run sudo apt update && sudo apt dist-upgrade to upgrade the kernel to the latest.
ok now what?, the last line says: Processing triggers for shim-signed:arm64 (1.38+15.4-7) …
sorry if im a bother
Reboot the system to run the new kernel.
so just unplug and re plug ?
Restart the system in software. sudo reboot
ok i did that but now it says the same thing as last time
edit: i did login with the user and password as last time
What is the exact make and model of the monitor?
Let me check, ill edit this msg
edit: LG moniter - LG FHD 32-inch computer moniter 32ML600M-B, IPS with HDR 10 Compatibiliy, Black, should i send an amazon link?
This should work as a standard 1080P monitor. Do you have a picture of what you are seeing?
i can send one if you would like
Please post a link to the image.
What’s wrong? This is the normal Raspbian Lite image.
oh, i think i got it confused with the desktop, i have two sd cards loaded, one with the desktop and one with lite, can you help me witht he desktop verison? i keep on getting a random colored screen
helo? can you help me with the full desktop?
milesk
April 25, 2023, 12:39am
39
I have no signal at all on my monitor. Red light solid, Green light solid, Blue light flashing.
I have already tried reflashing and running sudo apt update && sudo apt dist-upgrade
Thanks in advance for any advise.
ASUS VG248
1920x1080
00000000: 00ff ffff ffff ff00 0469 a524 0101 0101 .........i.$....
00000010: 1619 0103 8035 1e78 ea9d e5a6 5454 9f26 .....5.x....TT.&
00000020: 0d50 54b7 ef00 714f 8180 8140 81c0 8100 .PT...qO...@....
00000030: 9500 b300 0101 023a 8018 7138 2d40 582c .......:..q8-@X,
00000040: 4500 132b 2100 001e 0000 00fd 0032 4c1e E..+!........2L.
00000050: 5311 000a 2020 2020 2020 0000 00fc 0056 S... .....V
00000060: 4732 3438 0a20 2020 2020 2020 0000 00ff G248. ....
00000070: 0046 354c 4d51 5331 3537 3237 360a 01d4 .F5LMQS157276...
00000080: 0203 1ef1 4b90 0504 0302 0111 1213 141f ....K...........
00000090: 2309 0707 8301 0000 6503 0c00 1000 1a36 #.......e......6
000000a0: 80a0 7038 1e40 3020 3500 132b 2100 001a ..p8.@0 5..+!...
000000b0: 6621 56aa 5100 1e30 468f 3300 132b 2100 f!V.Q..0F.3..+!.
000000c0: 001e 011d 0072 51d0 1e20 6e28 5500 132b .....rQ.. n(U..+
000000d0: 2100 001e 8c0a d08a 20e0 2d10 103e 9600 !....... .-..>..
000000e0: 132b 2100 0018 011d 8018 711c 1620 582c .+!.......q.. X,
000000f0: 2500 132b 2100 009e 0000 0000 0000 003a %..+!..........:
00000000: 00ff ffff ffff ff00 1e6d 805b fe9b 0600 .........m.[....
00000010: 071f 0103 803c 2278 ea8c b5af 4f43 ab26 .....<"x....OC.&
00000020: 0e50 5425 4b00 7140 8180 81c0 a9c0 b300 .PT%K.q@........
00000030: d1c0 8100 d1cf 5aa0 00a0 a0a0 4650 3020 ......Z.....FP0
00000040: 3a00 5550 2100 001a 0000 00fd 0030 781e :.UP!........0x.
00000050: e63c 000a 2020 2020 2020 0000 00fc 004c .<.. .....L
00000060: 4720 554c 5452 4147 4541 520a 0000 00ff G ULTRAGEAR.....
00000070: 0031 3037 4e54 5557 4352 3135 300a 015d .107NTUWCR150..]
00000080: 0203 44f1 2309 0707 4d10 0403 011f 1312 ..D.#...M.......
00000090: 3f5d 5e5f 6061 6d03 0c00 1000 b83c 2000 ?]^_`am......< .
000000a0: 6001 0203 67d8 5dc4 0178 8003 e30f 0018 `...g.]..x......
000000b0: 681a 0000 0101 3078 00e3 05c0 00e6 0605 h.....0x........
000000c0: 0160 5928 d976 00a0 a0a0 3450 3020 3a00 .`Y(.v....4P0 :.
000000d0: 5550 2100 001a 565e 00a0 a0a0 2950 3020 UP!...V^....)P0
000000e0: 3500 5550 2100 001a 0000 0000 0000 0000 5.UP!...........
000000f0: 0000 0000 0000 0000 0000 0000 0000 0027 ...............'
James
May 13, 2023, 10:47pm
41
LG OLED65CX5LB
3180x2160p 30fps
00000000: 00ff ffff ffff ff00 31d8 0000 0000 0000 ........1.......
00000010: 0516 0103 6d32 1c78 ea5e c0a4 594a 9825 ....m2.x.^..YJ.%
00000020: 2050 5400 0000 d1c0 0101 0101 0101 0101 PT.............
00000030: 0101 0101 0101 023a 8018 7138 2d40 582c .......:..q8-@X,
00000040: 4500 f419 1100 001e 0000 00ff 004c 696e E............Lin
00000050: 7578 2023 300a 2020 2020 0000 00fd 003b ux #0. .....;
00000060: 3d42 440f 000a 2020 2020 2020 0000 00fc =BD... ....
00000070: 004c 696e 7578 2046 4844 0a20 2020 0005 .Linux FHD. ..
ahiru
May 15, 2023, 7:19pm
42
Getting a black screen after boot connecting HDMI to an LG 35WNC65C , whose native resolution is 3440x1440 @ 100Hz. (Board works when connected to a more normal 1080p monitor.)
Not looking for that full resolution and refresh rate of course, just would be nice to have it connected for easy input switching.
EDID dump below:
00000000: 00ff ffff ffff ff00 1e6d 5577 68c5 0000 .........mUwh...
00000010: 0320 0103 8052 2278 eea1 05a9 564b a425 . ...R"x....VK.%
00000020: 0f50 5421 0800 d1c0 6140 0101 0101 0101 .PT!....a@......
00000030: 0101 0101 0101 1dbf 7010 d1a0 6f50 6840 ........p...oPh@
00000040: ca04 345a 3100 001a 0000 00fd 0030 551e ..4Z1........0U.
00000050: 8431 000a 2020 2020 2020 0000 00fc 004c .1.. .....L
00000060: 4720 4844 5220 5751 4844 0a20 0000 00ff G HDR WQHD. ....
00000070: 0032 3033 4e54 5043 3147 3533 360a 013f .203NTPC1G536..?
00000080: 0203 4d73 2309 0707 8301 0000 4f61 605f ..Ms#.......Oa`_
00000090: 5e5d 5a59 2220 1f12 1004 0301 6d03 0c00 ^]ZY" ......m...
000000a0: 2000 b83c 2000 6001 0203 67d8 5dc4 0178 ..< .`...g.]..x
000000b0: 8003 e30f 0300 e200 6ae3 05c0 00e6 0605 ........j.......
000000c0: 0152 525e 681a 0000 0101 3055 00e7 7c70 .RR^h.....0U..|p
000000d0: a0d0 a029 5030 203a 0034 5a31 0000 1a9d ...)P0 :.4Z1....
000000e0: 6770 a0d0 a022 5030 203a 0034 5a31 0000 gp..."P0 :.4Z1..
000000f0: 1a00 0000 0000 0000 0000 0000 0000 00a5 ................
